Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
10-03-2016, 20:10 | #1 (permalink) |
Freak Poster Join Date: Jun 2016 Location: cairo
Member: 2587761 Status: Offline Thanks Meter: 30 | n915 note edge bootbricked |
The Following User Says Thank You to memonasser For This Useful Post: |
10-04-2016, 14:15 | #3 (permalink) |
No Life Poster Join Date: Sep 2013 Location: The Hell Age: 31
Member: 2033150 Status: Offline Thanks Meter: 624 | if u have only qcomm mode then u need to jtag it or simply u need to replace EMMC |
The Following User Says Thank You to xx0o0xx1 For This Useful Post: |
10-18-2016, 21:57 | #5 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Gizah/Egypt Age: 33
Member: 594436 Status: Offline Sonork: 100.1657777 Thanks Meter: 952 | BL is corrupted, need to repair it, Since this is a Qualcomm based device, you can flash only BL files to an SD Card then boot your device from that card until you get into Download mode, then reflash the device with Odin, Follow this guide: 1. Download debrick (BL) file from HERE, 2. Download Win32DiskImager from HERE, 3. Get an 32GB SD Card and connect it to PC, 4. Setup Win32 and Run it then do as the following picture, 5. Just let it finish, Then disconnect the SD Card, 6. Make sure the device's battery is well charged, 7. Put the SD Card into the phone, 8. Now you need to boot device into Download mode either by using USB JIG or by holding (Vol-, Home and Power), 9. Once device boot into Download, Pull out the SD, 10. Now just flash the phone with Latest FW (either Factory or One-Package will do the job), 11. There is no 11, we're done .. ##NOTE: Solution is TESTED and it works. Best Regards Last edited by MiRoOo; 10-18-2016 at 22:03. |
The Following 18 Users Say Thank You to MiRoOo For This Useful Post: |
04-17-2017, 22:11 | #8 (permalink) |
Major Poster Join Date: Feb 2007
Member: 446083 Status: Offline Thanks Meter: 9 | Works Perfectly on a SM-N915FY Thank you very much for the contribution It's a shame that the NOTE 4 SM-910F does not work as well, the boot-img image file Last edited by ...:::::NP™:::::...; 04-19-2017 at 21:49. Reason: Quote removed |
The Following User Says Thank You to caraconejo For This Useful Post: |
11-06-2017, 13:20 | #11 (permalink) | |
Freak Poster Join Date: Feb 2010 Location: turkey\bayburt
Member: 1232935 Status: Offline Thanks Meter: 15 | Quote:
hi sir thanks for your solution but when ı try to write bl to sd card win32disckimager do not see the file.what can ı do please help me where is wrong | |
The Following User Says Thank You to aktan2 For This Useful Post: |
11-07-2017, 08:16 | #12 (permalink) |
Junior Member Join Date: Nov 2017
Member: 2776097 Status: Offline Thanks Meter: 1 | This method worked for me 100% but when I try to flash fw I get re-partition failed. Even with the right pit file. And on the phone I get emmc write fail. Before it was bricked I had the message in download mode firmware upgrade encpuntered an issue. Please select recovery mode in kies and try again. Not thinking much I tried to root the phone thinking it will fix it. So it installed cmw and flashed SU and the kernel they provided with at the xda forum on the root n915f. Then it got bricked. Now I can go to download mode from this method but get re-partition fail message when trying to flash stock fw. Any suggestions? |
The Following User Says Thank You to Tutparko For This Useful Post: |
11-07-2017, 10:03 | #13 (permalink) |
Member: 1232935 Status: Offline Thanks Meter: 15 | sir when ı want to select bl file to write sd card no file for select.bl file ok but do not seen on win32discmanager |
11-08-2017, 00:18 | #14 (permalink) | |
Member: 594436 Status: Offline Sonork: 100.1657777 Thanks Meter: 952 | Quote:
When you choose the file, just change “*.img“ option to “All files“ from the browser window, it'll be in the bottom right and then you'll be able to choose *.bin file or any other file you want. Sent from my iPhone using Tapatalk | |
11-08-2017, 11:09 | #15 (permalink) | |
Major Poster Join Date: Apr 2017
Member: 2711575 Status: Offline Thanks Meter: 8 | Quote:
works like a charm! thanks mate | |
The Following User Says Thank You to jdkatumba For This Useful Post: |
