Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 05-06-2019, 15:34   #1 (permalink)
Member: 2763847
Thanks Meter: 29
N950F/DS/N U5 DRK Fix Solution ;)
https://drive.google.com/file/d/18GQ...qbZzVmYXp/view
Flash this full firmware
Fix for OEM lock ON DRK error
Works also on Prenormal or Normal or locked or anything RMM state/KG State.
Any DM Verity issue this will solve.
The Following 5 Users Say Thank You to AUGUSTIN45 For This Useful Post:
Old 06-14-2019, 16:09   #2 (permalink)
Crazy Poster
Member: 2742097
Thanks Meter: 7
What about U6 i have one with DRK problem knox 0 frp and oem off
Old 06-15-2019, 00:53   #3 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 1,161
flash combin to see it boot up or not
Old 07-12-2019, 18:14   #4 (permalink)
ikkks's Avatar
Member: 621455
Thanks Meter: 100
booting after flash combination
The Following User Says Thank You to ikkks For This Useful Post:
Old 07-13-2019, 01:38   #5 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 1,161
flash stock then root and it booting up
Old 07-13-2019, 08:28   #6 (permalink)
choksi's Avatar
Member: 2783412
Sonork: 1680285
Thanks Meter: 184
from 4 file, BL+AP+CP+CSC
open AP using 7zip and extract all partitions to one new folder
in that new folder make copy of boot.img so now you have 2 boot.img,
now delete recovery.img and rename one boot.img to recovery.img
or if it is recovery.img.lz4 then do so
now select all this files make tar using 7zip or any achiver
now flash this modified AP alongside with BL CP and csc
your problem will be solved
The Following User Says Thank You to choksi For This Useful Post:
Old 09-27-2019, 16:53   #7 (permalink)
Member: 2763847
Thanks Meter: 29
Update this to U7 or not? anyone want update?
Old 10-06-2019, 22:48   #8 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 451
I Have In Hands N950F U7 DRK Failed
On Combination Power On Ok
On Stock Stuck On Logo
With EFT And Some Other Trick Power On On Stock
But
After Boot Shows OEM Unlock In Settings
But
RMM STATE Prenormal
Tried Date And Time Method
Tried Many U7 Firmwares
But I Couldn't Manage To Make RMM STATE Completed/Checking Etc
I Need Help Please
Thanks Anticipation
Old 10-07-2019, 23:43   #9 (permalink)
Member: 2763847
Thanks Meter: 29
But
But
RMM STATE Prenormal
I Need Help Please
Thanks Anticipation
Flash efs.img and then flash combination U7 and in combination U7 install rlc app and freeze it with icebox and then flash stock firmware and trick for boot on no DRK and then done fully working no RMM state after done flash root and then use phone like normal
Old 10-08-2019, 09:11   #10 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 451
This RLC APP?
https://play.google.com/store/apps/d....android&hl=en
Or Any Else?
I Freezed This App With Ice Box - Apps freezer In Combination
But After Flashed With Stock Firmware
Fone Again Stuck On Logo
Need More Help Please
Thanks Anticipation
Old 10-08-2019, 10:35   #11 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 451
Ok Now I Got Your Point
Flashed COMBINATION
Installed Samsung_RLC APP
Installed Ice Box APP
Frozen RLC APP
Flashed Stock
And Again Stuck On Logo
Your Solution Not Worked ON U7
Old 11-08-2019, 18:50   #12 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 451
Nice Joke Buddy
When I Asked For ENG EFS?
Keep In Your Pocket Your ENG EFS
Old 11-09-2019, 04:38   #13 (permalink)
Member: 1762758
Sonork: 5611
Thanks Meter: 8
Nice Joke Buddy
Well, it's up to you. im not forcing anyone.
Old Yesterday, 15:55   #14 (permalink)
Member: 2763847
Thanks Meter: 29
Flashed COMBINATION
Frozen RLC APP
Flashed Stock
Sorry for late reply..If you still have the phone, have you flashed stock with HOME_CSC? If you use normal CSC it does not work.
Old Yesterday, 16:32   #15 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 451
At The Moment No Fone To Work
If Will Get , Will Post Result Here
Thanks For Your Sir
Page generated in 0.17357 seconds with 7 queries
