Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
02-04-2018, 19:30 | #1 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Sharja UAE
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | Need help, J327T drk failed need to repair J327t. phone drk is damage. phone stuck in recovery. i try to root phone but no success, then i write combination file, after that i write system from stock file. phone complete on, wifi ok but no Bluetooth also after some time phone reboot & stuck at panic logo. any solution to repair DRK? |
02-04-2018, 19:33 | #2 (permalink) |
Banned Join Date: Jan 2014 Location: Havana, Cuba Age: 40
Member: 2107306 Status: Offline Thanks Meter: 612 | Writing system from stock after combination does not solve drk problem. You need to flash combination, connect z3x with UART C3300K cable and make DRK_REPAIR over uart with GCPROKEY using COMPORT of z3x box. This is ABC for DRK repair, one of many use of combination is this, drk repair. |
The Following 2 Users Say Thank You to Prsctt For This Useful Post: |
02-05-2018, 03:43 | #3 (permalink) |
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | I don't have gcpro key, i have z3x pro and octuplus only, so tell me solution by these devices. Dose Gcpro key support tha model direct ? For repair drk? Or have to slect other model? If other model then tell me model name, i can try with my devices. |
02-05-2018, 04:54 | #4 (permalink) |
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | by trying other mode (N920T) in octupus by URT repair DRK failed. Code: Platform: Samsung Android Selected port: COM1 Selected model: SM-N920T Note: Type *#0*# on the phone and connect UART cable. Searching for device. Please wait... Found more then one box connected to COM11 Found phone on COM11 Reading info... Device model: SM-J327T Device IMEI: 35560308***** MSL address: R28J443TG4 DM-Verity verification.. Fixing DRK.. error 2 DRK fixing failed! Performed by 2.6.3 Software version. |
02-05-2018, 06:03 | #5 (permalink) | |
No Life Poster Join Date: Jan 2018
Member: 2802156 Status: Offline Thanks Meter: 173 | Quote:
OR ask for solution in octopus section and/or look for model with same cpu like j327a/f and use drk fix under those models | |
02-05-2018, 07:31 | #6 (permalink) | |
yes can fix DRK, you have working uart setup, stable internet connection, and phone is on combination? ALSO can't reply to your PM, check your settings in control panel: Hafiz ArslanAli has chosen not to receive private messages or may not be allowed to receive private messages. Therefore you may not send your message to him/her. | |
02-05-2018, 07:47 | #7 (permalink) | |
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | Quote:
i have good internet. stable port, & phone is on Combination file. give me any messanger id. | |
02-05-2018, 08:03 | #8 (permalink) |
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | u please check, dose Gcpro key this model for repair DRK ? by usb or uart. because in Z3x Pro & octupus box J327t not supported and others a,az,p supported but these phones are Qualcomm phones. |
02-05-2018, 15:48 | #9 (permalink) |
Member: 2107306 Status: Offline Thanks Meter: 612 | GCPRO needs no model selected, when you work over uart you don't need to select any model. This is the easy mode, there's other ways to do it for ex: flashing modified eng_root so DRK verification gets canceled. Using GCPRO over teamviewer will get your card blocked. |
03-01-2018, 19:47 | #13 (permalink) | |
Freak Poster Join Date: Dec 2011 Location: pakistan
Member: 1703671 Status: Offline Sonork: 100.1627623 Thanks Meter: 26 | Quote:
select combination file in z3x from this file only select boot & sboot click flash botton when complete urs phone gos to recovery menu hard reset the phone & wait untill phone completly on urs problem solve tested | |
03-26-2018, 18:22 | #14 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | but phone is restarting randomly & modem crash error .... |
The Following User Says Thank You to Aamir_Zia For This Useful Post: |
