Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
10-22-2015, 19:43 | #1 (permalink) |
Freak Poster Join Date: Jul 2007
Member: 554699 Status: Offline Thanks Meter: 52 | Need help with removing Reactivation Lock on Verizon Samsung Galaxy S5 I've seen a few snippets saying to do an EFS Clear. I haven't seen step-by-step or specific instructions. I see this option in ODIN, but I do not know if this is what needs to be done. Are there any ill effects of doing EFS Clear? Doesn't this also wipe out the IMEI of the phone? Thanks. |
10-23-2015, 01:52 | #3 (permalink) |
Freak Poster Join Date: Mar 2014 Location: morocco
Member: 2149341 Status: Offline Thanks Meter: 31 | Dont do the efs clear it will hang on logo an you will lost your original imei wich version of android do you have ? And did you try the usb jig method with the apk ? |
The Following User Says Thank You to Y0ussef12 For This Useful Post: |
10-23-2015, 16:30 | #4 (permalink) |
Member: 554699 Status: Offline Thanks Meter: 52 | Verizon OG5 stock lollipop 5.0 ROM. USB jig method with apk? I haven't done this, please tell me more. Thanks. Motorola DynaTAC 8000X using Tapatalk Last edited by AlpineMan; 10-23-2015 at 16:44. |
10-23-2015, 17:54 | #5 (permalink) |
Member: 554699 Status: Offline Thanks Meter: 52 | I found this interesting ad in ebay to remove Reactivation Lock. The seller requests for your IMEI and Samsung account and password. I'm thinking perhaps the way he removes the Reactivation Lock is this: 1) Acquire a Samsung phone in which the IMEI can be repaired w/o cert fail such as the Samsung Galaxy S4. 2) Flash your S5's IMEI (or whatever Samsung phone you have that needs to disable RL) on the S4. After so doing, on the S4, you can then enable, then disable the RL while logged into your Samsung Account. 3) This in turn disables the RL on the S5 as well. Just a theory. Interesting to try. If it works, then it'll work for ANY Samsung phone that has Reactivation Locked on ANY firmware. Unfortunately, I don't have an S4 to play with right now. Last edited by AlpineMan; 10-23-2015 at 18:04. |
10-23-2015, 18:07 | #6 (permalink) |
Member: 554699 Status: Offline Thanks Meter: 52 | Perhaps this will work even on phones that will do cert fail. Not necessary to do this on a phone such as the S4. As long as the phone has wifi and can connect to your Samsung account. |
10-24-2015, 14:56 | #8 (permalink) |
Moderator Join Date: Oct 2011 Location: U.A.E
Member: 1676524 Status: Offline Sonork: 100.1608473 Thanks Meter: 2,713 | Search on google efs tar for reactivation lock phone. if you get the efs then write it by odin. if normally will be done. otherwise u can try first upgrade firmware the phone. which firmware saperate pda,csc, modem and bootloader. if any bypass video not working on your version then try to follow my step. i was face that problem in note 3. that time didn't get any bypass video on youtube. if you didn't getting efs.tar for your phone then u should find out same phone on your nearby location. read efs from working phone & write it reactivation phone. this procedure just my idea & my successfully work report. nothing else. just do it own your risk!! br, shamim |
10-24-2015, 16:32 | #9 (permalink) |
Junior Member Join Date: Sep 2014
Member: 2261727 Status: Offline Thanks Meter: 3 | I used efs clear and repartition option on the note 3 before and it didn't wipe out the imei but it helped me to remove the pin locked screen. Can you try efs clear and repartition option with the pit file off course ? and please report back the result. I have the at&t s5 and I can't find the stock odin for the phone. Now I can't turn the reactivation lock off. I turned it off in settings and it still turn back on. I also tried to delete samsung account and factory reset the phone as someone suggested but the reactivation lock is stil there. Last edited by waiwai; 10-24-2015 at 16:38. |
10-25-2015, 04:45 | #10 (permalink) |
Insane Poster Join Date: Aug 2013 Location: Uruguay
Member: 2003494 Status: Offline Thanks Meter: 39 | ok you have luck i am posting the solution i will back to the link Edit: http://forum.gsmhosting.com/vbb/f777...1-1-a-2005623/ |
10-25-2015, 05:01 | #11 (permalink) |
Member: 554699 Status: Offline Thanks Meter: 52 | Thanks, but the solution posted on that video won't work for me. My phone has been factory reset. It won't allow me to get past the Samsung Reactivation Lock screen. Motorola DynaTAC 8000X using Tapatalk |
10-25-2015, 15:40 | #12 (permalink) | |
Member: 554699 Status: Offline Thanks Meter: 52 | Quote:
I have a Z3X box. Ill see if I can use that to create one. | |
11-09-2015, 21:28 | #13 (permalink) |
Member: 554699 Status: Offline Thanks Meter: 52 | I got the S5 working. Since I didn't have an S4 to experiment with, I ended up paying a Reactivation unlock service via ebay. For some reason though, I'm unable to disable the Reactivation Lock via phone settings once I got through. So every time you factory reset the phone, it will prompt for the Samsung account to bypass the lock. On another note, I also tried the same Reactivation unlock service on a Verizon Note 4. I actually tried 2 services that did the same thing just to verify my findings. For some reason, it didn't work for both. I discovered that the actual IMEI of the motherboard didn't match the IMEI sticker. I'm thinking perhaps the Reactivation Lock was enabled using the old IMEI. We tried both IMEI's and it didn't work. I'm thinking there must be some sort of mismatch going on that's preventing the unlock to work. A tip...a couple of ways to find your phone's actual IMEI if you can't bypass the Reactivation Lock to get to phone settings: 1) Go to Windows device manager. Right click on Samsung modem, click on Properties. Do a "Query Modem". YMMV. This worked on a Verizon S5, but not on a Verizon Note 4 and T-Mobile Note Edge. 2) On the modem properties, look for modem initialization string. Put "AT+CGSN". Turn on modem logging. Create an internet dial up connection to dial any phone number. Proceed with the dial up. Inspect the modem log in Windows device manager. IMEI should be shown. YMMV. This worked on a Verizon Note 4, but didn't work on a T-Mobile Note Edge. |
The Following User Says Thank You to AlpineMan For This Useful Post: |
08-17-2017, 04:35 | #14 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 307625 Status: Offline Thanks Meter: 25 | nothing will work all these methods been tried and more only way to remove the reactivation is with gsnp access, program called samsung capture tool if aim wrong than correct me ,,,,,,,,,,,,,with proof |
