Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
03-01-2017, 08:59 | #4 (permalink) |
Insane Poster Join Date: Oct 2013 Location: Bangladesh
Member: 2038498 Status: Offline Sonork: 100.1668482 Thanks Meter: 24 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Write CERT' to restore certificates. 7. Press 'Write NV DATA' if you need to restore NV backup. Read certificate operation: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read CERT' button to read certificates. Operation: Write CERT Selected model: SM-G925F Software version: 27.7 Waiting ADB device... Ok Reading phone info... Model: SM-G925F Android version: 5.1.1 Product code: Phone version: G925FXXU3COI9 PDA version: G925FXXU3COJ1 CSC version: G925FOJP3COJ1 CSC country code: Iraq CSC sales code: MID HW version: Phone SN: Chip name: EXYNOS7420 Modem board: SHANNON333 RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... error Security damaged (1) Done with Samsung Tool PRO v.27.7 |
03-01-2017, 11:19 | #5 (permalink) |
Moderator Join Date: Mar 2011 Location: metasploit Age: 31
Member: 1537689 Status: Offline Sonork: 100.1669550 Thanks Meter: 2,219 | status of your phone imei and baseband ok..?
__________________ To get Instant help use "search" & follow "sticky thread"..!!! By respecting/following forum rules,You will be respected .! Best Wishes : [IMG]****************************/convkey/0fa4/qq0zcyol0fmauiu6g.jpg[/IMG] .:::Roy:::. |
