p1000 problem when trying to flash... 2 Attachment(s) hi all,i followed the tutorial in how to flash the samsung p1000 but i am stuck at one point. i have flashed it with the pit file and i got the green passed message so i took out the usb cable and clicked reset and then i selected the flash files so i put the p1000 in download mode again and clicked "start" but here i made a photo of what happens... the first photo is what happened when i clicked start the second photo is after,when i tried again to press start. im stuck at the second photo,please if anybody could give me an hand it would be great!! thanks a lot in advance |
please please any help?im still stuck :( |
is there any expert who can solve me this problem?i am happy to pay via paypal for some remote help! thanks |
No matter you write PIT or not, when you are using 3part file, u should use PIT file again, also mark Re-Partition |
please any other help,i am still stuck when it says: setup connection please im willing to pay via paypal for a real help thanks |
i faced this problem yesterday Disconnect all you boxs,modems and external devices and restart your pc, install samsung android modem and then try if dosen't answer , use another computer that be clean of other boxes software and drivers i used another computer and solved :) |
i was able to go a l |
1 Attachment(s) i was able to go a little further and i got where it says: <ID:0/003> Added!! <ID:0/003> Odin v.3 engine (ID:3).. <ID:0/003> File analysis.. <ID:0/003> Enter CS for MD5.. <ID:0/003> Leave CS.. <ID:0/003> Enter CS for MD5.. <ID:0/003> Leave CS.. <ID:0/003> Enter CS for MD5.. <ID:0/003> Leave CS.. <ID:0/003> Set PIT file.. <ID:0/003> DO NOT TURN OFF TARGET!! <ID:0/003> Get PIT for mapping.. <ID:0/003> Firmware update start.. <ID:0/003> modem.bin <ID:0/003> boot.bin <ID:0/003> Sbl.bin <ID:0/003> param.lfs <ID:0/003> factoryfs.rfs <ID:0/003> <ID:0/003> Complete(Write) operation failed. <OSM> All threads completed. (succeed 0 / failed 1) <ID:0/003> Removed!! <ID:0/003> Added!! <ID:0/003> Odin v.3 engine (ID:3).. <ID:0/003> File analysis.. <ID:0/003> Set PIT file.. <ID:0/003> DO NOT TURN OFF TARGET!! <ID:0/003> Can't open the specified file. (Line: 1044) <OSM> All threads completed. (succeed 0 / failed 1) <ID:0/003> Removed!! <ID:0/003> Added!! <ID:0/003> Odin v.3 engine (ID:3).. <ID:0/003> File analysis.. <ID:0/003> Enter CS for MD5.. <ID:0/003> Leave CS.. <ID:0/003> Enter CS for MD5.. <ID:0/003> Leave CS.. <ID:0/003> Enter CS for MD5.. <ID:0/003> Leave CS.. <ID:0/003> Set PIT file.. <ID:0/003> DO NOT TURN OFF TARGET!! <ID:0/003> Get PIT for mapping.. <ID:0/003> Firmware update start.. <ID:0/003> modem.bin <ID:0/003> boot.bin <ID:0/003> Sbl.bin <ID:0/003> param.lfs <ID:0/003> factoryfs.rfs <ID:0/003> <ID:0/003> Complete(Write) operation failed. <OSM> All threads completed. (succeed 0 / failed 1) it starts flashing but it gives me failed after a little bit,what could be the problem???perhaps wrong files? thanks a lot in advance i am also posting a photo to explain better where i am at thanks again |
also what are these files: cache.rfs dbdata.rfs factoryfs.rfs param.lfs zImage i dont know how to flash them,odin doesnt let me select them for flashing i was able to use: P1_add_hidden.pit GT-P1000-CSC-MULTI-OXXJK2.tar.md5 MODEM_P1000XXJK5_REV_00_CL690077.tar.md5 P1000XWJJ7-REV03-ALL-CL669843.tar.md5 please somebody can clear me out the differences among those files? thanks again |
i discovered that all the files: cache.rfs dbdata.rfs factoryfs.rfs param.lfs zImage are inside P1000XWJJ7-REV03-ALL-CL669843.tar.md5 so when i flash the p1000 i have to flash all modem csc and P1000XWJJ7-REV03-ALL-CL669843.tar.md5 or i can only flash the last file and the pit file? thanks a lot |
try another version. . |
i have the same problem on two phones freind please help us |
heeeeeeeeeelp please |
Here is what you must note some firmwares come with just one file and that is the pda, flashing the pda you must put pit 512 and the pda file and flash, after using only the pit and partion option, do not extract the tar file some firmwares when extracted from rar has 3 files, phone, pda, csc in flashing these files you must put a hidden pit in pit tab and check repartition then start, (only pit) when it show pass load the the 3 files without pit and without repartition. Reasons for that error, firmware downgrade is atimes not allowed by bootloader, so if you are not sure, always go for the latest firmwares in support. Eg if the phone had jk1, you must flash jk2 before jk5 so if you are not sure, go for firmwares that has no extention use jm5 firmware i recommend. |
perform the same procedure with this firmware p1000_xwjmf from News - www.**************** 100% firmware problem you have |
