Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 12-17-2014, 00:31   #1 (permalink)
Member: 2209517
Thanks Meter: 134
plez hellp how to s7562 disable test mode
hello
plez hellp how to
i have box
octupse
spt
z3x
gpgemmc
Old 12-17-2014, 08:16   #2 (permalink)
Super Moderator
~Leo~'s Avatar
Member: 224065
Sonork: 100.1577902
Thanks Meter: 7,930
Test mode ?! Post photo of this test mode !
Sent from my iPhone using Tapatalk
__________________
USE "THANKS" Button.
Follow Forum Rules
OFFLINE and Away
The Following User Says Thank You to ~Leo~ For This Useful Post:
Old 12-17-2014, 08:22   #3 (permalink)
axecom's Avatar
Member: 1424719
Sonork: 100.1619833
Thanks Meter: 2,563
Check buttons(power and volume)...
If not Post in the appropriate Box section to get better support.
Regards,
Axecom
The Following User Says Thank You to axecom For This Useful Post:
Old 12-18-2014, 10:36   #4 (permalink)
santosh178's Avatar
Member: 1713823
Sonork: sai
Thanks Meter: 143
Originally Posted by h11kurd View Post
these tow images
أرسلت بواسطة iPhone بإستخدام Tapatalk
use spt
first clear efs with spt box
after clear efs your handset will ok
but imei will null
now rewrite imei
The Following User Says Thank You to santosh178 For This Useful Post:
Old 12-18-2014, 10:49   #5 (permalink)
shailccna's Avatar
Member: 350232
Thanks Meter: 207
if not solved prob plz change vilume button if not solved then changed touch at last ....
The Following User Says Thank You to shailccna For This Useful Post:
Old 12-20-2014, 10:57   #6 (permalink)
Member: 2209517
Thanks Meter: 134
I worked reset EFS spt
And repair imei z3x
Thank you
Old 12-20-2014, 10:59   #7 (permalink)
Member: 2209517
Thanks Meter: 134
Old 12-27-2014, 14:33   #8 (permalink)
Member: 1742275
Thanks Meter: 56
Originally Posted by santosh178 View Post
use spt
but imei will null
now rewrite imei
*#87976633# enter code test ok
problem solved 100%%%%%
The Following User Says Thank You to nokias12 For This Useful Post:
Old 01-27-2015, 17:40   #9 (permalink)
Member: 1283066
Thanks Meter: 5
look for the efs path / FactoryApp / factorymode
select the file: factorymode open the menu and give edit
open the file you will see that this change it OFF to ON , guards and restart the cell
Page generated in 0.17592 seconds with 8 queries
