Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
09-26-2013, 13:48 | #1 (permalink) |
No Life Poster Join Date: Dec 2000 Location: las palmas ,spain
Member: 2800 Status: Offline Thanks Meter: 47 | Problem with s4 i9505:display goes blank while calling I dont know where is the problem cos i ve flashed many phones with this flash v4.22 and only faced problem with 2. |
09-29-2013, 10:12 | #7 (permalink) |
Freak Poster Join Date: Mar 2012 Location: Sargodha(Pakistan)
Member: 1736467 Status: Offline Sonork: 1613563 Thanks Meter: 46 | if u have protector on it. then remove it. and try. 2nd solution is open phone and see if there is dust on aprox sensenor. clean it. hope it will work. |
10-10-2013, 15:59 | #9 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Z <> A Age: 49
Member: 413160 Status: Offline Sonork: 100.1657278 Thanks Meter: 96 | today i got same problem with my s4 it was lock on 3 i flash with this firmware I9505XXUAMDD_I9505EVRAMDA_I9505XXUAMDD_HOME.tar.md 5 after unlock whenever i make a call its lcd gone blank is there any solution ?? |
08-14-2014, 15:02 | #12 (permalink) |
Insane Poster Join Date: Feb 2010 Location: .:FUTURE:.
Member: 1243462 Status: Offline Sonork: 100.1667252 Thanks Meter: 38 | try to change lcd or proxcimity sensor, its hardware problem tested by me many times! post result...... |
The Following User Says Thank You to ragznarok For This Useful Post: |
08-14-2014, 15:02 | #13 (permalink) |
Junior Member Join Date: Jul 2009
Member: 1066525 Status: Offline Thanks Meter: 1 | Try to change the LCD and try to call it again. I incounter that kind of problem, i've tried everything but no luck. Then i tried to change LCD before i will return the CP to my *******r then to my surprise it worked. Hope it can help. |
The Following User Says Thank You to shadow_tech For This Useful Post: |
