-   Samsung Android based phones (http://forum.gsmhosting.com/vbb/f777/)
-   -   Remove password i9100 and tricks master reset (http://forum.gsmhosting.com/vbb/f777/remove-password-i9100-tricks-master-reset-1483343/)
samwel02 05-30-2012 16:05
If your device is frozen and unresponsive, press and hold for 8 - 10 seconds. The device will reboot automatically.
If this does not solve the problem, perform a factory data reset. In Idle mode, open the application list and select
Settings / Privacy / Factory data reset / Reset phone / Erase everything.
OR
Use this method to hard reset your Samsung Galaxy S II phone: Enter *2767*3855#. Warning! All your data including contacts, messages etc. will be lost! Copy all your necessary data / Contacts / Messages etc. to SIM or make backup on your PC before full reset!
OR
1. Turn off the i9100 S 2 phone or take out the battery and reinsert it.
2. Hold the Volume Down button
3. Press and release the Power button
4. Select Clear Storage by pressing the Volume Down button
5. Press and release the Power button
6. Press Volume Up to confirm i9100 master reset
OR
VERY IMPORTANT IF THE PHONE IS BLOCKED BY A PASSWORD YOU FOLLOW EVERY STEP UNLOCK ONE BY ONE
* 1 * Turn the POWER OFF, pull the battery out and put it back again
* 2 * PRESS AND HOLD VOLUME UP + Home Button Keep pressing two buttons thesis + press Power button for 2-3 Seconds only Release power button , KEEP pressing Volume Up + Home Buttons
* 3 * With volume down select wipe data / factory reset (N3) and press home button
*4* enter 3 or 4 time 8 to zero as password
*5* Wait 'till the process completes, Once the wipe is completed, the Samsung Galaxy S II l9100 will then reboot. All the data you previously installed already been deleted and then the phone will then return to its original factory fresh default settings.
do not forget to type * thank you * to samwel02 AND I LIKE TO MAHDIA HI-TECH (FACEBOOK)
Page generated in 0.12984 seconds with 5 queries
