Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
03-18-2014, 22:44 | #1 (permalink) |
No Life Poster Join Date: Feb 2014
Member: 2136780 Status: Offline Thanks Meter: 68 | repair softbrick not3 I FINALLY RESTORED NOTE 3 FROM SOFT BRIKED ! THIS TUTORIAL IS FOR ONLY NOTE 3 ( N-9005 ) SNAPDRAGON ONLY ! IF WILL NOT HELP THIS ONE http://forum.gsmhosting.com/vbb/f777.../#post10175657 ----------------- THEN READ BELOW------------------- If you have symptons like : - RESTARTING AFTER 30 SEC WHEN SYSTEM IS READY. - BRIGHTNES BAR MISSING - APPLICATIONS FORCE CLOSING - IN SAMSUNG MENAGER SYSTEM STORAGE IS 16 GB INSTEAD OF 32 GB - DIALER DOES NOT WORK. - POWER BUTTON DOES NOT WORK. - IF YOU TRIED TO INSTALL OTHER ROMS AND STILL THE SAME SYMPTONS Then this manual is for you WHAT WE NEED : - clean rom like N9005XXUDMJ7_N9005OXADMJ4_BTU for example - my pit file http://www.***************/GNZBN4QUIW - odin 3.09 http://www.***************/00K2JQD45C - samsung drivers http://www.***************/UCYN9O1VFF - adb http://www.***************/VU164H9Y20 - efs professional http://www.***************/8AQP1AC1N6 - n9005-cwm-recovery-6.0.4.4(1025) - recovery http://www.***************/7W1OQVGXU6 - UPDATE-SuperSU-v1.65 - Superuser http://www.***************/ALFN3R16HY - and my files http://www.***************/2JAM5R6ILF PREPARATIONS : - install samsung drivers - extract NOTE 3 - Fix soft bricked.rar and put files on your extended sd card. and UPDATE-SuperSU-v1.65.zip as well - go to download mode - install via Odin some clean rom and use pit file as well and check boxes in odin : nand erase all, Re-partition Phone efs clear - after install rom go into recovery and make full wipe - odin again and install n9005-cwm-recovery-6.0.4.4(1025) ( button AP in odin ) - go to recovery - install zip - choose extended sd card - UPDATE-SuperSU-v1.65.zip - boot system ( su has to be installed ) - go to recovery again - mounts and storage mount system mount extended sd card - put USB cable to computer - run adb commands : adb shell su dd if=/external_sd/mmcblk0p1 of=/dev/block/mmcblk0p1 dd if=/external_sd/mmcblk0p2 of=/dev/block/mmcblk0p2 dd if=/external_sd/mmcblk0p3 of=/dev/block/mmcblk0p3 dd if=/external_sd/mmcblk0p4 of=/dev/block/mmcblk0p4 dd if=/external_sd/mmcblk0p5 of=/dev/block/mmcblk0p5 dd if=/external_sd/mmcblk0p6 of=/dev/block/mmcblk0p6 dd if=/external_sd/mmcblk0p7 of=/dev/block/mmcblk0p7 dd if=/external_sd/mmcblk0p8 of=/dev/block/mmcblk0p8 dd if=/external_sd/mmcblk0p9 of=/dev/block/mmcblk0p9 dd if=/external_sd/mmcblk0p10 of=/dev/block/mmcblk0p10 dd if=/external_sd/mmcblk0p11 of=/dev/block/mmcblk0p11 dd if=/external_sd/mmcblk0p12 of=/dev/block/mmcblk0p12 - first try skip this command ( I had to make this but maybe you do not have to and your imei number will remain but do not worry we can back imei number very easily but sim card still don't connect to carrier - I'm working on it. dd if=/external_sd/mmcblk0p13 of=/dev/block/mmcblk0p13 - first try skip this command ( I had to make this but maybe you do not have to and your imei number will remain but do not worry we can back imei number very easily but sim card still don't connect to carrier - I'm working on it. dd if=/external_sd/mmcblk0p14 of=/dev/block/mmcblk0p14 dd if=/external_sd/mmcblk0p15 of=/dev/block/mmcblk0p15 dd if=/external_sd/mmcblk0p16 of=/dev/block/mmcblk0p16 dd if=/external_sd/mmcblk0p17 of=/dev/block/mmcblk0p17 dd if=/external_sd/mmcblk0p18 of=/dev/block/mmcblk0p18 dd if=/external_sd/mmcblk0p19 of=/dev/block/mmcblk0p19 dd if=/external_sd/mmcblk0p20 of=/dev/block/mmcblk0p20 dd if=/external_sd/mmcblk0p21 of=/dev/block/mmcblk0p21 dd if=/external_sd/mmcblk0p22 of=/dev/block/mmcblk0p22 dd if=/external_sd/mmcblk0rpmb of=/dev/block/mmcblk0rpmb - wait 30 sec and put out the battery. - unplug the phone - switch on the phone - should boot normally and work properly - but your imei number i probably gone and your sn number is gone as well . But do not worry we repair it ! RESTORING SN - SEIAL NUMBER : - we need HxD Hex Editor HxD - Freeware Hex Editor and Disk Editor | mh-nexus - and need mmcblk0p11 - open mmcblk0p11 in HxD Hex Editor go to adres ( offset ) edit -> choose block -> 602000 - you should find RF000000000 - replace with your proper SN. - go to recovery again - mounts and storage mount system mount extended sd card - put USB cable to computer - run adb commands : adb shell su dd if=/external_sd/mmcblk0p11 of=/dev/block/mmcblk0p11 - wait 30 sec and put out the battery. - Now your SN should be ok. If your IMEI number is ok - finish -------------------------------- BUT IT IS NOT READ BELOW: http://forum.gsmhosting.com/vbb/f777/script-fix-soft-brick-loop_-efs-partition_01-11-13-a-1791958/#post10175657 if won't help READ MORE - firsr try this - on dial pad dial *#0808# - choose RMNET+DM+MODEM and pres ok - plug the phone to computer , wait until drivers will be installed - run EFS Professional, choose Quallcom NV tools - click connect, - on the bottom is imei repair put your right imei number - choose write to device and just write - unplug phone , dial again *#0808#, choose MTP+ADB - restart phone and your imei should be again ok. |
