Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 03-18-2014, 22:44   #1 (permalink)
mike_shinoda's Avatar
Member: 2136780
Thanks Meter: 68
repair softbrick not3
YOU CAN BELIVE IT !
I FINALLY RESTORED NOTE 3 FROM SOFT BRIKED !
THIS TUTORIAL IS FOR ONLY NOTE 3 ( N-9005 ) SNAPDRAGON ONLY !
IF WILL NOT HELP THIS ONE http://forum.gsmhosting.com/vbb/f777.../#post10175657
----------------- THEN READ BELOW-------------------
If you have symptons like :
- RESTARTING AFTER 30 SEC WHEN SYSTEM IS READY.
- BRIGHTNES BAR MISSING
- APPLICATIONS FORCE CLOSING
- IN SAMSUNG MENAGER SYSTEM STORAGE IS 16 GB INSTEAD OF 32 GB
- DIALER DOES NOT WORK.
- POWER BUTTON DOES NOT WORK.
- IF YOU TRIED TO INSTALL OTHER ROMS AND STILL THE SAME SYMPTONS
Then this manual is for you
WHAT WE NEED :
- clean rom like N9005XXUDMJ7_N9005OXADMJ4_BTU for example
- my pit file http://www.***************/GNZBN4QUIW
- odin 3.09 http://www.***************/00K2JQD45C
- samsung drivers http://www.***************/UCYN9O1VFF
- adb http://www.***************/VU164H9Y20
- efs professional http://www.***************/8AQP1AC1N6
- n9005-cwm-recovery-6.0.4.4(1025) - recovery http://www.***************/7W1OQVGXU6
- UPDATE-SuperSU-v1.65 - Superuser http://www.***************/ALFN3R16HY
- and my files http://www.***************/2JAM5R6ILF
PREPARATIONS :
- install samsung drivers
- extract NOTE 3 - Fix soft bricked.rar and put files on your extended sd card. and UPDATE-SuperSU-v1.65.zip as well
- go to download mode
- install via Odin some clean rom and use pit file as well and check boxes in odin :
nand erase all,
Re-partition
Phone efs clear
- after install rom go into recovery and make full wipe
- odin again and install n9005-cwm-recovery-6.0.4.4(1025) ( button AP in odin )
- go to recovery - install zip - choose extended sd card - UPDATE-SuperSU-v1.65.zip
- boot system ( su has to be installed )
- go to recovery again - mounts and storage
mount system
mount extended sd card
- put USB cable to computer
- run adb commands :
adb shell
su
dd if=/external_sd/mmcblk0p1 of=/dev/block/mmcblk0p1
dd if=/external_sd/mmcblk0p2 of=/dev/block/mmcblk0p2
dd if=/external_sd/mmcblk0p3 of=/dev/block/mmcblk0p3
dd if=/external_sd/mmcblk0p4 of=/dev/block/mmcblk0p4
dd if=/external_sd/mmcblk0p5 of=/dev/block/mmcblk0p5
dd if=/external_sd/mmcblk0p6 of=/dev/block/mmcblk0p6
dd if=/external_sd/mmcblk0p7 of=/dev/block/mmcblk0p7
dd if=/external_sd/mmcblk0p8 of=/dev/block/mmcblk0p8
dd if=/external_sd/mmcblk0p9 of=/dev/block/mmcblk0p9
dd if=/external_sd/mmcblk0p10 of=/dev/block/mmcblk0p10
dd if=/external_sd/mmcblk0p11 of=/dev/block/mmcblk0p11
dd if=/external_sd/mmcblk0p12 of=/dev/block/mmcblk0p12 - first try skip this command ( I had to make this but maybe you do not have to and your imei number will remain but do not worry we can back imei number very easily but sim card still don't connect to carrier - I'm working on it.
dd if=/external_sd/mmcblk0p13 of=/dev/block/mmcblk0p13 - first try skip this command ( I had to make this but maybe you do not have to and your imei number will remain but do not worry we can back imei number very easily but sim card still don't connect to carrier - I'm working on it.
dd if=/external_sd/mmcblk0p14 of=/dev/block/mmcblk0p14
dd if=/external_sd/mmcblk0p15 of=/dev/block/mmcblk0p15
dd if=/external_sd/mmcblk0p16 of=/dev/block/mmcblk0p16
dd if=/external_sd/mmcblk0p17 of=/dev/block/mmcblk0p17
dd if=/external_sd/mmcblk0p18 of=/dev/block/mmcblk0p18
dd if=/external_sd/mmcblk0p19 of=/dev/block/mmcblk0p19
dd if=/external_sd/mmcblk0p20 of=/dev/block/mmcblk0p20
dd if=/external_sd/mmcblk0p21 of=/dev/block/mmcblk0p21
dd if=/external_sd/mmcblk0p22 of=/dev/block/mmcblk0p22
dd if=/external_sd/mmcblk0rpmb of=/dev/block/mmcblk0rpmb
- wait 30 sec and put out the battery.
- unplug the phone
- switch on the phone - should boot normally and work properly
- but your imei number i probably gone and your sn number is gone as well .
But do not worry we repair it !
RESTORING SN - SEIAL NUMBER :
- we need HxD Hex Editor HxD - Freeware Hex Editor and Disk Editor | mh-nexus
- and need mmcblk0p11
- open mmcblk0p11 in HxD Hex Editor go to adres ( offset ) edit -> choose block -> 602000 - you should find RF000000000 - replace with your proper SN.
mount system
adb shell
su
- Now your SN should be ok.
If your IMEI number is ok - finish
BUT IT IS NOT READ BELOW:
http://forum.gsmhosting.com/vbb/f777/script-fix-soft-brick-loop_-efs-partition_01-11-13-a-1791958/#post10175657
if won't help READ MORE
- firsr try this
- on dial pad dial *#0808#
- choose RMNET+DM+MODEM and pres ok
- plug the phone to computer , wait until drivers will be installed
- run EFS Professional, choose Quallcom NV tools
- click connect,
- on the bottom is imei repair put your right imei number
- choose write to device and just write
- unplug phone , dial again *#0808#, choose MTP+ADB
- restart phone and your imei should be again ok.
Old 03-19-2014, 06:06   #2 (permalink)
ansari123's Avatar
Member: 292789
Thanks Meter: 636
any way for note3 n900w8 imei repair ///???
Old 04-07-2014, 18:12   #3 (permalink)
Member: 2136780
Thanks Meter: 68
you can reapir imei with spt
Old 09-23-2014, 16:48   #4 (permalink)
..::\/\/::..'s Avatar
Member: 1294131
Sonork: 16919899
Thanks Meter: 579
dear mike_shinoda not work your download links ,,chek plz
Page generated in 0.16479 seconds with 9 queries
