Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 02-07-2017, 07:20   #1 (permalink)
Member: 2365276
Thanks Meter: 9
[ROOT] SM-G925A root file [Available]
G925A root 6.0.1 file need
The Following 4 Users Say Thank You to it-soft For This Useful Post:
Old 02-24-2017, 02:17   #2 (permalink)
Temporary banned !!
Member: 2511938
Thanks Meter: 118
text me.
i have root g920a g925a g891 n920v 6.0.1
full root access
The Following User Says Thank You to bypassfrp For This Useful Post:
Old 02-25-2017, 15:35   #3 (permalink)
Member: 359956
Thanks Meter: 10
Can you add a link my brother
The Following User Says Thank You to delikan_042 For This Useful Post:
Old 02-25-2017, 16:34   #4 (permalink)
Member: 359956
Thanks Meter: 10
I need so much please g925a 6.0.1 root addin
Old 02-26-2017, 00:54   #5 (permalink)
banziitox24's Avatar
Member: 2051392
Thanks Meter: 157
If someone need eng root for G920A Latest Version and G925A Latest version PM me I have available
Old 02-26-2017, 14:11   #6 (permalink)
Member: 92260
Thanks Meter: 805
Samsung G920A UCU5xxxx v6.0.0 Eng Root Boot
No need to contact anybody, cuz sharing is caring!!
Here's the G920A Eng Root Boot, works with all boot version 5 firmwares.
Enjoy!!
Samsung_G925A_UCU5xxxx_v6.0.0_Eng_Boot_Root.TAR
Like this G925A root 6.0.1 & CERT Write Done
The Following 7 Users Say Thank You to BillA For This Useful Post:
Old 04-13-2017, 23:27   #7 (permalink)
Member: 1815016
Thanks Meter: 60
Here's the G925A Eng Root Boot, works with all boot version 5 firmwares.
Enjoy!!
https://www.androidfilehost.com/?fid=817550096634749297
ADB isn't enabled by default, like it normally is with an eng kernel. You don't happen to have one of those versions, do you? Trying to bypass a screen lock so obviously can't enable adb manually
Old 04-14-2017, 09:36   #8 (permalink)
Member: 2706092
Thanks Meter: 1,470
we have root bro and B5
Old 07-16-2017, 19:41   #9 (permalink)
Crazy Poster
Member: 1967570
Thanks Meter: 6
I need Root for G925a N920A
Old 07-18-2017, 08:27   #10 (permalink)
Member: 1787195
Sonork: 100.1617895
Thanks Meter: 26
Originally Posted by bypassfrp View Post
text me.
full root access
i want g925a root file
Old 08-20-2017, 23:38   #11 (permalink)
Member: 2266238
Thanks Meter: 52
Enjoy!!
https://www.androidfilehost.com/?fid=745425885120711078
Samsung_G920A_UCU5xxxx_v6.0.0_Eng_Boot_Root.TAR
Bro MOdel is G925A but the link is G920A is it possible
flash this file after may be phone stuck
Old 08-21-2017, 00:18   #12 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 9,862
Hi, the firmware download link is fixed with the correct model firmware link.
__________________
Use Search Button to get Instant Result | Follow Forum Rules
Avoid Spams in the forum to prevent ban your account.
Old 08-21-2017, 00:48   #13 (permalink)
Member: 2539108
Thanks Meter: 225
Bro Not Found Root Mount System For 6.0.1
ROOT FOUND FOR 6.0.1 FOR FIX DM AND UNLOCK NETWORK
not Worked For Add Languge
For Add Languge You Need Downgrade To 5.1.1 and flash root mount system
link for root 6.0.1 not mount
https://easy-firmware.com/index.php?...tegory&id=7391
And Root 5.1.1 mount system search in xda found
Old 08-21-2017, 00:54   #14 (permalink)
Moderator
Member: 1162626
Thanks Meter: 9,862
Please again check the post no #6
__________________
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post:
Old 02-18-2018, 03:45   #15 (permalink)
Member: 2810355
hola que tal amigo necesito ayuda para liberar g925a versionde android 7.0 tengo z3x se puede con ese eng boot? 6.0 ??
The Following User Says Thank You to humbert9000 For This Useful Post:
Page generated in 0.32592 seconds with 7 queries
