Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 06-28-2013, 12:40   #16 (permalink)
Member: 1948001
Thanks Meter: 4
how i root this my galaxy s2
Old 06-28-2013, 23:14   #17 (permalink)
Member: 1159099
Thanks Meter: 6,316
Hello friend this question is already answered in this section,check following link
root Samsung Galaxy S2
Old 07-23-2013, 16:36   #18 (permalink)
faisal jee's Avatar
Member: 882981
Sonork: 161363
Thanks Meter: 190
Originally Posted by Braycel View Post
same problam pls any body help me
Old 07-30-2013, 14:04   #19 (permalink)
Member: 1900437
Thanks Meter: 106
Yippppeeeeeeeeeeeee that worked... It was great help. Thanks. Will it work for other Android's as well? Means those by Samsung.... Just a query?
Old 08-21-2013, 16:06   #20 (permalink)
Member: 1249391
Thumbs up thanks
Originally Posted by liong15 View Post
After flashing cwm via odin, should pull off the battery first and then turn on the handheld in cwm mode. after that try to flash the update-supersu.zip again
Hope it helps
Sent from my iPad using Tapatalk HD
i have tried to flash cwm many times and the update-supersu.zip always failed. but when i tried to follow this system of not allowing phone to reboot after update, removing battery and then go to recovery to update-supersu.zip, it works fine.
thanks for the suggestion.
Old 08-22-2013, 13:59   #21 (permalink)
Member: 1900437
Thanks Meter: 106
Didn't worked for mine.... Do help me up with my Grand
Old 09-10-2013, 12:58   #22 (permalink)
prasutirur's Avatar
Member: 1541938
Sonork: kerala
Thanks Meter: 23
I need samsung i9082 schematics
& charging solution
Old 09-24-2013, 17:23   #23 (permalink)
Member: 2032230
what if [volume down]+[home button]+[power button] and phone doen't goes in download mode. as it is copy phone i purchase from bangkok, and i get network error. i tried to in download mode but phone ***** any response by pressing [volume down]+[home button]+[power button] (all at once). what to do??
Old 11-19-2013, 19:36   #24 (permalink)
Member: 477086
?????? root for i9082,,, that s one not work
Old 01-12-2014, 15:39   #25 (permalink)
Member: 1185991
sure solution to all
you must first before rooting grand which update 4.2.2 you must flash the mobile with stock frimware then rooting it ...... tested by me in two phones
Old 01-13-2014, 21:58   #26 (permalink)
himanshucbr's Avatar
Member: 1697041
Sonork: 1609691
Thanks Meter: 67
Originally Posted by drozd View Post
How to Root I9082 / I9082L -
STEP BY STEP rooting manual for GSM-Hosting users
Just follow this simple steps:
1. Step
- Download Samsung USB drivers ----> Click HERE
- Download ODIN 3.04 from ----> Click HERE
- Download i8092 recovery image prerooted ----> Click HERE
- Download SuperSu Last version ----> Click HERE
2. Step
- Turn off phone, then switch to download mode:
press together [volume down]+[home button]+[power button] (all at once),
press [volume up] for comfirm download mode.
- Connect usb cable, install drivers.
3. Step
- Run Odin 3.04, ticked 2 option F.reset times+auto reboot,
- Extract CWM-touch_i9082_chotu.tar.zip !Select PDA and browse to where you have extracted CWM-touch_i9082_chotu.tar.md5
and select it
4. Step
- Odin should show device under 1 of ID:COM port.(if this not happends repeat from STEP 2)
- Press START.
- Phone should power on after flashing complete.
5. Step - ROOTING:
- Copy Downloaded SUperSU to externel sdcard (NOT INTERNAL ! )
- Power off your phone, after press [Vol up] + [Power] + [Home button] (all at once)
- SelectInstall zip from sdcard --->choose zip from sdcard ---> scroll down and select Fix Recovery.zip and
again choose zip from sdcard and flash UPDATE-SuperSU-v1.05.zip
Done ! And you are ready to go
thanks goes to chotu.
pls uplooad file in 4shared and medifire
hotfile site is permanently blocked
pls share this file
Old 01-13-2014, 22:43   #27 (permalink)
Member: 2101578
how to root sansumg galaxy star plus S7262 ?
Old 01-15-2014, 13:09   #28 (permalink)
CHAPRAN's Avatar
Member: 31906
Thanks Meter: 100
help....
Originally Posted by gsmsikar View Post
i am also having this same problem , i have done exactly same as is written ?
same problem ...i done many i9082 but this cant
Old 01-16-2014, 05:40   #29 (permalink)
Member: 2095964
Re: [Root] step by step Manual i9082 (L) Galaxy GRAND
As far as I am concerned about the same I think the update bearing build number I9082XXUBMGA is currently available for users in Russia and is expected to reach other parts of the world soon.
Old 01-16-2014, 06:45   #30 (permalink)
Member: 2103277
can I wipe my phone after root?
Page generated in 0.33947 seconds with 7 queries
