Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
![]() | #1 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Dec 2001 Location: USA
Member: 7805 Status: Offline Thanks Meter: 173 | [Root] step by step Manual i9105 (P) Galaxy S2 Plus STEP BY STEP rooting manual for GSM-Hosting users Just follow this simple steps: 1. Step - Download Samsung USB drivers ----> Click HERE - Download ODIN 3.04 from ----> Click HERE - Download CWMtouch-i9105_chotu.tar.md5.zip recovery image from here ------> Click HERE! for other type fw (Indian) download this recovery image ---> Click HERE! - Download SuperSu Last version ----> Click HERE 2. Step - Turn off phone, then switch to download mode: press together [volume down]+[home button]+[power button] (all at once), press [volume up] for comfirm download mode. - Connect usb cable, install drivers. 3. Step - Run Odin 3.04, ticked 2 option F.reset times+auto reboot, - Extract CWM-touch_i9082_chotu.tar.zip !Select PDA and browse to where you have extracted CWM-touch_i9105_chotu.tar.md5 or CWM-touch_i9105_Indian_chotu.tar.md5 and select it 4. Step - Odin should show device under 1 of ID:COM port.(if this not happends repeat from STEP 2) - Press START. - Phone should power on after flashing complete. 5. Step - ROOTING: - Copy Downloaded SUperSU to externel sdcard (NOT INTERNAL ! ) - Power off your phone, after press [Vol up] + [Power] + [Home button] (all at once) - SelectInstall zip from sdcard --->choose zip from sdcard ---> scroll down and select Fix Recovery.zip and again choose zip from sdcard and flash UPDATE-SuperSU-v1.05.zip Done ! And you are ready to go ![]() thanks goes to chotu. |
The Following 15 Users Say Thank You to drozd For This Useful Post: |
![]() | #2 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2007
Member: 534602 Status: Offline Thanks Meter: 30 | on I9105P does not work Selected model: I9105P Selected port: COM28 Z3X Serial Port Selected port speed: 115200 Reading phone info... Model: GT-I9105P Android version: 4.1.2 Product code: Unknown Phone version: I9105PXXAMA1 PDA version: I9105PXXAMA2 CSC version: I9105POXXAMA1 IMEI: Unknown Checking Super user right... false Rooting phone, please wait... error Not supported android version 4.1.2 Done with Samsung Tool v.14.2 Tried flashing with different versions of ODIN and it does not accept CWM. i flashed it 5 times and only the normal Recovery mode is on the phone. |
![]() | #3 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: May 2005 Location: Timisoara Age: 37
Member: 146635 Status: Offline Sonork: 100.1651273 Thanks Meter: 258 | not working on i9105 p recovery menu normal cannot find this " select Fix Recovery.zip" superuser not ok sign cannot be verified upload here good superuser |
![]() | #5 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2004 Location: Poland, Wroclaw Age: 44
Member: 67562 Status: Offline Sonork: none Thanks Meter: 88 | Could that 3 files (in first post) be packed in one package? After get first file have to wais half hour... ![]() ![]() ![]() |
![]() | #7 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2006
Member: 228717 Status: Offline Thanks Meter: 28 | Quote:
hi where i found the file "CWMtouch-i9105_chotu.tar.md5" ??? when i download i just get this file CWMtouch-i9105_chotu.tar.md5[1].zip74 Downloads, 6 MB and canīt extract it solution ??? can you upload correct file ?? kanks | |
![]() | #9 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2009
Member: 1083358 Status: Offline Thanks Meter: 182 | OSM> CWMtouch-i9105_chotu.tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/057> Odin v.3 engine (ID:57).. <ID:0/057> File analysis.. <ID:0/057> SetupConnection.. <ID:0/057> Complete(Write) operation failed. <ID:0/057> Added!! <OSM> All threads completed. (succeed 0 / failed 1) |
![]() | #10 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2006 Location: Greece Age: 31
Member: 396924 Status: Offline Thanks Meter: 33 | I have installed This Package For ODin but after when em trying to install SuperSU from External Card . it says "verification failed" Why and when em trying to Download SuperSU from Google Play (After Installation) It says "This Is no SU binary Installed, And SuperSU cannot install it This is a Problem" What is Wrong ? |
![]() | #12 (permalink) | |
Member: 1083358 Status: Offline Thanks Meter: 182 | Quote:
![]() | #13 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2003 Location: Romania Age: 43
Member: 41105 Status: Offline Thanks Meter: 39 | download from nspro suport firmware for unlock, write this in phone and use spt box for unlock... enjoy |
The Following User Says Thank You to kuli For This Useful Post: |
![]() | #15 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2009
Member: 1085379 Status: Offline Thanks Meter: 65 | I found rooted stock firmware in the web Worked perfectly try that Sent from my LT26i using Tapatalk 2 |
The Following User Says Thank You to coolmfarshard For This Useful Post: |
