Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 05-13-2013, 18:54   #1 (permalink)
Drug_Store's Avatar
Member: 15312
Sonork: 100.1576041
Thanks Meter: 1,097
S4 i9505 cant flash stock - modem fail odin
Hello,
I have here a i9505 that I canīt flash stock rom by odin, because always fail to flash modem part...
Tried 2 or 3 diferent roms, but no sucess.
Phone works but canīt turn WIFI on, a warning appears to restart the device.
Model : GT-I9505
Version : 4.2.2
Base : XXUAMD2
Kernel : 3.4.0-526204
Compile : JDQ39.I9505XXUAMDN
ODIN Mode:
Current Binary : Custom
System Status : Custom
CSB-OEM_CONFIG_LSB : 0x30
Write Protection : Enabled
Any tips?
Thank you
Old 05-13-2013, 19:57   #2 (permalink)
MOBILECHANNEL's Avatar
Member: 746449
Sonork: 100.1603972
Thanks Meter: 171
Flash with odin3 3.o7
Old 05-14-2013, 00:08   #3 (permalink)
Drug_Store's Avatar
Member: 15312
Sonork: 100.1576041
Thanks Meter: 1,097
Using 3.0.7 already
Old 05-14-2013, 00:31   #4 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
Thanks Meter: 18,268
Hi Sir ,
Try Use This Firmware
Hotfile.com: One click file hosting: I9505XXUAME1_I9505YOGAMDB_YOG.zip
Old 05-14-2013, 12:17   #5 (permalink)
Drug_Store's Avatar
Member: 15312
Sonork: 100.1576041
Thanks Meter: 1,097
Originally Posted by Mohsin-* View Post
I will, but which differences has?
Old 05-14-2013, 21:50   #6 (permalink)
Drug_Store's Avatar
Member: 15312
Sonork: 100.1576041
Thanks Meter: 1,097
Made no diference, still fail to flash modem part.
Old 05-15-2013, 07:20   #7 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,052
Are you using the right pit file?
you can donwload it HERE
Alex
Old 05-17-2013, 09:56   #8 (permalink)
Drug_Store's Avatar
Member: 15312
Sonork: 100.1576041
Thanks Meter: 1,097
When I try to flash PIT file, with re-partition ticked... phone shows Security check fail, and odin3.0.7 just remains stopped.
Old 05-18-2013, 08:01   #9 (permalink)
Super Moderator
Member: 813309
Thanks Meter: 1,912
Maybe Your Phone Have Locked Bootloader
BootLoader verrouillé sur les Samsung Galaxy S4 ? | Phonandroid
Old 05-20-2013, 11:57   #10 (permalink)
Drug_Store's Avatar
Member: 15312
Sonork: 100.1576041
Thanks Meter: 1,097
Originally Posted by Braycel View Post
Yes this might be an issue... however, this unit is an engineer model from samsung pre-launch S4, so, might be some kind of upgrade blockage.
Old 06-09-2013, 17:33   #11 (permalink)
Member: 1956627
Hi did you ever resolve this? I have the same problem, also with a pre launch model.
Thanks.
Old 07-26-2013, 11:00   #12 (permalink)
Member: 1928034
Same here with my SGS4. The phone is from samsung, but i dont think it's pre launch model. The Baseband version is I9505XXUAMCL and i have the same problem when i try to flash new rom - when it gets to the modem it fails to write. And i can't repartition with the .pit file.
Old 07-29-2013, 05:47   #13 (permalink)
Member: 1000009
Sonork: no sonork id
Thanks Meter: 20
any solution to this prob? i have one here also
Old 07-31-2013, 14:35   #14 (permalink)
Member: 293775
i have same problem.
i try to unlock but *#7284# not work , after i try with *#0808# i conect but not unlock.
i flash it with odin but fail, (write protection enable).
phone is dead and i not flash him
Old 08-02-2013, 18:08   #15 (permalink)
Member: 215142
Thanks Meter: 3
Good day, please I have an issue with a samsung galaxy s4 i9505 which a customer brought to my shop for flashing. The phone came with samsung galaxy s4 GT-19505 showing on the screen with a tiny writing at the top left hand corner which says recovery booting......, that is how it stays. I have flashed it with three different os with odin, but at end everything was successful. It shows PASS at the end, but it does not boot pass the initial screen display. Can anyone tell me what the problem could be and how to solve it. Tanx in advance.
Page generated in 0.25972 seconds with 9 queries
