Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
11-08-2013, 19:49 | #31 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
The Following User Says Thank You to allumts For This Useful Post: |
11-09-2013, 06:25 | #32 (permalink) | |
Insane Poster Join Date: Nov 2011 Location: Quetta,Pakistan
Member: 1682308 Status: Offline Sonork: ahadalami Thanks Meter: 14 | Quote:
<OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/006> Odin v.3 engine (ID:6).. <ID:0/006> File analysis.. <ID:0/006> SetupConnection.. <ID:0/006> Initialzation.. <ID:0/006> Get PIT for mapping.. <ID:0/006> There is no PIT partition. <OSM> All threads completed. (succeed 0 / failed 1) <ID:0/006> Removed!! Snapshot_2013-11-09_102112.png | |
11-09-2013, 07:02 | #33 (permalink) |
Member: 1682308 Status: Offline Sonork: ahadalami Thanks Meter: 14 | I tried with z3x box n it gave me this log Selected model: I9505 Selected port: COM5 Z3X BOX Serial Port Selected port speed: 115200 File analysis... OK Total file size: 0x9BEF8AB8 Searching USB Flash Interface... detected COM6 Setup connection... OK Reading PIT from phone... OK Saved to C:\Program Files\Z3X\Samsung\SamsungTool\Pit\I9505_9-11-2013_11-1-24.pit Sending boot.img... OK Sending cache.img.ext4... Error Done with Samsung Tool v.16.1 |
11-09-2013, 10:36 | #34 (permalink) | |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | Quote:
can you please upload this file C:\Program Files\Z3X\Samsung\SamsungTool\Pit\I9505_9-11-2013_11-1-24.pit at here or some file sharing web? Regards, Chevli | |
11-09-2013, 14:15 | #35 (permalink) | |
bootloader + pit_I9505 Br Max | |
11-10-2013, 05:43 | #36 (permalink) | ||
Quote: | ||
11-11-2013, 09:28 | #37 (permalink) |
Freak Poster Join Date: Dec 2005 Location: inside nibiru
Member: 205990 Status: Offline Thanks Meter: 73 | if the device is already in version 4.3 and your trying to flash it with a lower version... flash it w/o pit and bootloader.. however you will lose your wifi.. if the device is from lower version and you trying to upgrade it and having such error inspite that you are using the correct odin version and correct tar files then it is a hardware problem... |
The Following User Says Thank You to gsm_freak For This Useful Post: |
11-11-2013, 13:30 | #38 (permalink) |
Freak Poster Join Date: Jan 2009 Location: egypt
Member: 946879 Status: Offline Sonork: 100.1615133 Thanks Meter: 20 | download this and Flash with odin3 3.o7 Dev-Host - I9505XXUDMH8-PRE-ROOTED-KNOX_FREE-ODEX-FULL.rar - The Ultimate Free File Hosting / File Sharing Service |
11-11-2013, 17:30 | #39 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | GT-I9505-Factory-Firmware-Full-Wipe-DBT.zip https://my.pcloud.com/#page=publink&...cOmsxRtzkOqGP7 After try to flash whith Good Fw separate files, (conseje), Home.Tar w/o Pit and Odin 1.85, tested by me |
11-13-2013, 17:09 | #40 (permalink) | |
Your Br. Alami | |
06-24-2014, 13:01 | #41 (permalink) |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,282 | JUST FLASH MODEM PART NO NEED PIT FILE IT COM ALIVE AGAIN Welcome to Octoplus/Octopus Box Samsung software version 1.5.9 ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. Selected firmware file: I9505XXUFNA1-MODEM.oct Please switch your phone to the download mode and connect it to a PC. To put GT-I9505 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing MDM section... MDM section has been written successfully. Firmware writing successfully completed. |
03-13-2016, 13:11 | #44 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Have closed access becouse if you loock Data of Post is to many out datate and many user can do only ERROR. It's post from 2013 now are in 2016, warning first of post. Anyway cecked Now Link is Full working!!! BR allumts |
