Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
06-24-2018, 10:08 | #1 (permalink) |
Junior Member Join Date: Jun 2018
Member: 2846520 Status: Offline Thanks Meter: 0 | S6 edge g925i stuck at samsung logo ( does any one has solutions ) I flashed with the latest stock rom 7.0 from sammobile official website and it keeps stucking at samsung all the time. If i downgrade it then sboot . bin , param . bin will be error. Also i flashed without the sboot . bin , param . bin and downgraded but nothing happen still stucking at samsung all the time. I also flashed it with twrp and lineage os and after that it successfully booted up . The lineage os is working but it has so many bugs in my phone that was really useless. Bugs are sounds not working, videos are not recorded by camera only capturing the photos, phone call sound not working, battery drain so fast that was really stupid with in a 15 minutes without doing anythings. Also, the phone heated so much. I flashed the official rom and the current binary was samsung official and system status was custom. Like the below ODIN MODE PRODUCT NAME: SM-G925I CURRENT BINARY: Samsung Official System Status: Custom REACTIVATION LOCK: OFF AP SWREV: B:4 K:2 S:2 So, i just wanted to flash the original rom in my galaxy s6 edge phone and when i flashed it stucks in samsung. Questions are ?
Anyone has solutions to fix it then please answer. |
06-24-2018, 10:58 | #2 (permalink) |
No Life Poster Join Date: Sep 2008 Location: Space Age: 49
Member: 861795 Status: Offline Thanks Meter: 1,275 | After flashing official firmware (try multi firmware and pit), reboot to recovery and check DRK (dm-verity error)... If there is DRK error, try rooting your phone and check if it boots normally... |
06-24-2018, 13:52 | #3 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Online Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | I think you can only successfully access the download mode? or Did you check, can you access the recovery mode? If you can not access the recovery mode, change your LCD or remove the touch screen connection from the LCD part.
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
06-25-2018, 08:38 | #5 (permalink) |
Member: 861795 Status: Offline Thanks Meter: 1,275 | Try this firmware , and use Pit file: G925IDVU4FRD3 - 7.0 - KSA (Saudi Arabia) - Multi Firmware + PIT.zip |
The Following User Says Thank You to voltran2008 For This Useful Post: |
07-03-2018, 06:43 | #8 (permalink) | |
Member: 2846520 Status: Offline Thanks Meter: 0 | Quote:
So, i tried and i think the problem is system status become custom and after flashing all file successfully till now the system binary is official and system status is custom. Did you know how i can make system status official. | |
07-03-2018, 09:05 | #10 (permalink) |
Member: 2846520 Status: Offline Thanks Meter: 0 | That doesn't make any sense and i can't find firmware using sn. Just answer me that how i can make system status official not custom. Only system binary will be official after full flash not system status. |
07-03-2018, 09:22 | #11 (permalink) | |
Freak Poster Join Date: Jan 2014 Location: india
Member: 2112210 Status: Offline Thanks Meter: 32 | Quote:
hang on logo done, don't custom rom install Last edited by raajalams; 07-03-2018 at 09:28. | |
07-05-2018, 10:52 | #12 (permalink) | |
May be emmc damage or what ? Solution please | |
07-06-2018, 08:59 | #13 (permalink) |
Member: 2846520 Status: Offline Thanks Meter: 0 | Yes the drk is error and after rooting also same problem. I leaved it for more than 6 hours of flashing official firmware and 4 firmware but still it stucks. Only custom rom works with many bugs such as camera, phone call, etc. |
07-21-2018, 07:16 | #14 (permalink) |
Member: 861795 Status: Offline Thanks Meter: 1,275 | Flash this firmwre and pot result: G920IDVS4FRCA - 7.0 - BNG (Bangladesh) - Multi Firmware + PIT.zip |
