Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
07-19-2015, 10:15 | #16 (permalink) |
No Life Poster Join Date: Sep 2008 Location: Space Age: 49
Member: 861795 Status: Offline Thanks Meter: 1,275 | G920FXXU2BOFL G920FXXU2BOFJ G920FXXU2POFC G920FXXU2BOFO G920FXXU2POFD G920FXXU2POG3 |
The Following User Says Thank You to voltran2008 For This Useful Post: |
07-19-2015, 10:17 | #17 (permalink) | |
Freak Poster Join Date: Sep 2007 Age: 41
Member: 591658 Status: Offline Thanks Meter: 14 | Quote:
Thanks i will try this the g960f i have country is Philippies network Suncellular. i will give feedback if it gets OK. Last edited by robin3; 07-19-2015 at 10:23. | |
07-19-2015, 12:25 | #18 (permalink) | |
Member: 861795 Status: Offline Thanks Meter: 1,275 | Quote:
Firmware: SM-G920F - GALAXY S6 PDA: G920FXXU2BOFO CSC: G920FOLB2BOFF Version: 5.1.1 Country: Philippines Operator: Sun Cellular Product code: XTE Single File - Official mediafire.com - G920FXXU2BOFO_G920FOLB2BOFF_XTE.zip | |
07-20-2015, 09:46 | #19 (permalink) |
Freak Poster Join Date: Nov 2012 Location: Born in Syria,Live In Turkey
Member: 1834175 Status: Offline Thanks Meter: 51 | Here you go OHHHHH >>ALL BROTHERS THIS IS TOP SOLUTION: MOST OF ERRORS IS AT HIDDEN PART SO: REMOVE THIS PART THEN FLASH THE FIRMWARE ALL DONE :-) BEST REGARD Eng.SALMAN FARAJ (SYRIA-JARABLOS) |
07-20-2015, 10:54 | #20 (permalink) | |
your case is true on scenarios with branded and some open firmwares... for those firmware device needs bigger hidden partition and if you dont have enough partition Odin fails while flashing... but i dont own the device thats why i cant be totally sure, if this scenario is true with pit or without pit... because original G920F pit is "ZEROFLTE_EUR_OPEN.pit" but there are other pit files: ZEROFLTE_EUR_OPEN_HIDDEN50M.pit ZEROFLTE_EUR_OPEN_HIDDEN100M.pit the ony difference between pit files is the hidden part, the partition size is larger for ex. ZEROFLTE_EUR_OPEN.pit: 240KB, ZEROFLTE_EUR_OPEN_HIDDEN100M.pit: 400 KB i have previously tested "ZEROFLTE_EUR_OPEN_HIDDEN100M.pit" with some branded firmwares and it failed at hidden part... anyway hidden part is operator specific, and for open firmwares country or zone specific(it contains nothing but bloatware apps), it is safe to flash without hidden part... | |
07-21-2015, 05:27 | #21 (permalink) | |
08-14-2015, 16:18 | #22 (permalink) |
Junior Member Join Date: Oct 2011
Member: 1677475 Status: Offline Thanks Meter: 0 | hi i try to root my s6 with cf root. root is okey and after that it stuck on samsung and something is written in red on top of screen. can anyone help me please so much worried, you guys are so genius please help me |
11-19-2015, 00:48 | #28 (permalink) |
Banned Join Date: Mar 2011
Member: 1539068 Status: Offline Thanks Meter: 74 | can you tell me how to check S6 serial number, when back glass is broken and software is messed up showing only downloading screen.. i need to find proper file to update software, no imei no serial number, thanks |
01-10-2016, 15:34 | #30 (permalink) | |
Freak Poster Join Date: Feb 2008 Location: Esam Telecom Age: 43
Member: 696206 Status: Offline Sonork: 100.1597401 Thanks Meter: 262 | Quote:
If you've tried to flash firmware off of Sammobile, and had your heart stop when the flash fails, fear no longer. To fix the soft brick: Open the firmware file in winrar and extract the hidden.img. Rename it as hidden.img.tar. Load the new file into the PDA tab, and flash. When the phone boots, the displayed image will be touchwiz teal, there will be a little android and GALAXY spelt above it. Don't freak out. Give it a minute and it should boot. | |
The Following 2 Users Say Thank You to mdmosheur For This Useful Post: |
