Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 02-04-2013, 18:25   #1 (permalink)
naizersky's Avatar
Member: 540512
Thanks Meter: 340
s7562. firmware 4.0.4 how to root
Old 02-04-2013, 20:13   #2 (permalink)
ceza031's Avatar
Member: 1724862
Thanks Meter: 448
How to Root Samsung Galaxy S Duos S7562
STEPS OF INSTALLATION
  • Download the Samsung Galaxy S Rooting Kit zip file and extract to some folder, you should receive a tar file.
  • Open odin 3 Which is extracted form the root kit and put the tar file in pda.
DOWNLOAD FİLE
  • Put the device into download mode. (vol down + home + power button, and then click on vol up)
  • Connect phone to usb and wait for odin detect the device.
  • Click start.
  • Let Odin complete The Following Process, don't interrupt the process.The green bar tell you the Progress of the operation.When the green box in Odin Windows shows "pass" your phone will start a Reboot.
  • After it when the Phone starts,Copy CWM Superuser v 3.1.3.zip in your internal or external sd card and then Again switch off the Phone.
  • Go to CWM recovery by pressing Vol up+Vol Down+Home+Power Button simultaneously.
  • Then select install zip from sd card and then choose CWM Superuser v 3.1.3.zip And install it.
  • Then Reboot System Now...Now enjoy the power of super user in your Phone.
DOWNLOAD FİLE
The Following 2 Users Say Thank You to ceza031 For This Useful Post:
Old 02-05-2013, 17:11   #3 (permalink)
naizersky's Avatar
Member: 540512
Thanks Meter: 340
odin step ok.... after CWM Superuser v 3.1.3.zip install errer.... my firmware 4.0.4 is new....... help me
Old 02-07-2013, 17:27   #4 (permalink)
naizersky's Avatar
Member: 540512
Thanks Meter: 340
s7562. firmware 4.0.4 rooted done.......... UnlockRoot/UnlockPhone/UnlockRom---Android Root
Old 02-11-2013, 15:53   #5 (permalink)
Member: 626209
Thanks Meter: 42
HI. A never rooted phone when you enter download mode after you pass the warning by pressing volume up displays this:
[ODIN3]
PRODUCT: GT-S7562
VERSION:
CUSTOM BINARY DOWNLOAD: NO
CURRENT BINARY: SAMSUNG OFFICIAL
SYSTEM STATUS: OFFCIAL
The word after "SYSTEM STATUS:" is actually spelled OFFCIAL so it's not my mistake. What I wanna know is if this phone can be rooted one way or another so the "CUSTOM BINARY DOWNLOAD:" counter doesn't change to "YES 1 count(s)" because this is the first thing the guys at official Samsung service center check for. The methods mentioned above most definitely change the counter so warranty is lost. I could even do with a TEMROOT like is the case with some phones but not all.
Thanks in advance.
Old 03-22-2013, 03:05   #6 (permalink)
Member: 204827
Thanks Meter: 46
These root method works on S7562L also?
Old 04-02-2013, 00:12   #7 (permalink)
Member: 204827
Thanks Meter: 46
Tested on S7562L 100% works
Old 05-16-2013, 11:12   #8 (permalink)
Member: 724562
Thanks Meter: 217
virüsss Do not install this program
I condemn these people
The Following User Says Thank You to looupss For This Useful Post:
Old 07-06-2013, 10:15   #9 (permalink)
Member: 1014826
Thanks Meter: 88
Ithink This Thread Have These Lines Are Missing .Read Carfully
When the phone reboots, a vibration will signify that the phone has shut down completely. Don't let the phone to boot just after the phone vibrates, remove the battery. So we prevented the phone to boot again as this would've activated the install-recovery.sh script to re-install the stock recovery. You can now disconnect your phone from the pc.
Old 09-18-2013, 17:31   #10 (permalink)
Member: 2028604
[ODIN3]
PRODUCT: GT-S7562
VERSION:
Thanks in advance.
So when a s7562 is new and received any root or custom firmware, it displays what you wrote. I have to send my s7562 to warranty service and i must know if this message is the default message in download mode of s7562 (i thought [ODIN3] and OFFCIAL was not normal, i thought it must display ODIN MODE in red and OFFICIAL without mistake) so i need your final confirmation. Thanks
[ODIN3]
PRODUCT: GT-S7562
VERSION:
Old 08-30-2014, 11:10   #11 (permalink)
Member: 2249184
I get following error on apply update from external storage.
E:failed to verify whole-file signature
E:signature verification failed.
I am using GT 7652 India make.
Old 09-10-2014, 17:05   #12 (permalink)
NOKIA EXPERT's Avatar
Member: 2227489
Thanks Meter: 190
use THIS TOOL 100% WORKING MANY SET TESTED ME
ANDROID ROOT LINK
Hit Thanks it boosts me
The Following 2 Users Say Thank You to NOKIA EXPERT For This Useful Post:
Old 04-14-2016, 10:06   #13 (permalink)
Member: 997828
tahmks boss its woring
Old 04-17-2016, 17:14   #14 (permalink)
Member: 598532
Thanks Meter: 6
you can try kingroot..download the apk install and run
Page generated in 0.24536 seconds with 8 queries
