Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 01-14-2015, 15:26   #1 (permalink)
Member: 2249287
Thanks Meter: 25
Samsung S7582 White LCD After Flash [Solution Available]
hello all
we face here a new problem with model S7582 the white screen after flash
i try many times but this the last solution
i will write what i search about it may be right or no
if you try to flash any kies firmware your problem still.
if you open your Kies firmware you will find this
and if you open any factory room for example
when you extract all files using 7zip program
as you see in kies firmware you didn't found BcmBoot.img or kyleprods.pit
for this note i try to flash with full firmware and i success
i flash with this firmware with odin 1.85
Download
Firmware
odin 1.85
this solution success with me in may be 10 pecs
Please share if you care and put your result here
Regards
mMK-DEV
The Following 24 Users Say Thank You to mMK-DEV For This Useful Post:
Old 01-16-2015, 15:55   #2 (permalink)
GSM_HABIB's Avatar
Member: 1199125
Sonork: 100.1609676
Thanks Meter: 297
bro link not work give another link
The Following User Says Thank You to GSM_HABIB For This Useful Post:
Old 01-16-2015, 16:17   #3 (permalink)
mobite's Avatar
Member: 1800009
Sonork: 100.1654307
Thanks Meter: 806
Here
Download file THL-S7582XXUANG1-20140724090458.zip
The Following 2 Users Say Thank You to mobite For This Useful Post:
Old 01-25-2015, 18:40   #4 (permalink)
Member: 205475
Thanks Meter: 179
thanx it solve the problem 80% but until now the lines appear
The Following User Says Thank You to anasshe For This Useful Post:
Old 01-25-2015, 18:58   #5 (permalink)
Member: 205475
Thanks Meter: 179
sorry it solve the problem 100% but after software the lines still so i attached it to charger after some minutes the screen became ok thanx again
Old 02-09-2015, 09:51   #6 (permalink)
Member: 2236209
Thanks Meter: 5
bro please update the link it not downloading
The Following 2 Users Say Thank You to MasoudjR For This Useful Post:
Old 02-12-2015, 18:01   #7 (permalink)
Member: 1765830
Sonork: 100.1617139
Thanks Meter: 54
work with me did you try again
The Following User Says Thank You to khalafawy For This Useful Post:
Old 02-13-2015, 19:09   #8 (permalink)
NKhan_Gsm's Avatar
Member: 1646177
Sonork: 100.1604654
Thanks Meter: 369
As it is new hardware specially its LCD when you flash new hardware with old firmware you will get this problem after flash so you had better flash with latest versions for this model and also this problem can be solved by replacing LCD but we had better solve the problem caused by flashing by Software .
WBR
The Following 2 Users Say Thank You to NKhan_Gsm For This Useful Post:
Old 02-14-2015, 12:43   #9 (permalink)
maxpro12's Avatar
Member: 1369772
Thanks Meter: 297
Hi mMK-DEV,
Please upload the file mediafire or goole drive
The Following User Says Thank You to maxpro12 For This Useful Post:
Old 03-10-2015, 11:59   #10 (permalink)
Member: 2272184
Thanks Meter: 2
i have same problem i tried four different flash file but problem not solved please upload file ...thanks
The Following User Says Thank You to samir_paudel99 For This Useful Post:
Old 03-27-2015, 17:37   #11 (permalink)
Member: 821134
download this S7582XXUANL3_OXEAOA1
The Following User Says Thank You to djamaldeldoul For This Useful Post:
Old 03-28-2015, 09:14   #12 (permalink)
tsarkh's Avatar
Member: 165812
Sonork: 100:1627635
Thanks Meter: 4,267
Here are the same firmware version uploaded on 4shared:
S7582XXUANG1 Repair Firmware
Share If U Care
The Following User Says Thank You to tsarkh For This Useful Post:
Old 03-28-2015, 15:28   #13 (permalink)
tsarkh's Avatar
Member: 165812
Sonork: 100:1627635
Thanks Meter: 4,267
Here is the right link:
S7582XXUANG1_Repair_Firmware
Share If U Care
The Following 4 Users Say Thank You to tsarkh For This Useful Post:
Old 03-31-2015, 08:08   #14 (permalink)
czaren's Avatar
Member: 735013
Thanks Meter: 74
tsar both links are broken
The Following 3 Users Say Thank You to czaren For This Useful Post:
Old 03-31-2015, 08:26   #15 (permalink)
tsarkh's Avatar
Member: 165812
Sonork: 100:1627635
Thanks Meter: 4,267
Share If U Care
This is 100% working, Please check again.
Share If U care
The Following 2 Users Say Thank You to tsarkh For This Useful Post:
Page generated in 0.24312 seconds with 9 queries
