Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
01-14-2015, 15:26 | #1 (permalink) |
Junior Member Join Date: Aug 2014 Location: xda-developers
Member: 2249287 Status: Offline Thanks Meter: 25 | Samsung S7582 White LCD After Flash [Solution Available] hello all we face here a new problem with model S7582 the white screen after flash i try many times but this the last solution i will write what i search about it may be right or no if you try to flash any kies firmware your problem still. if you open your Kies firmware you will find this and if you open any factory room for example when you extract all files using 7zip program as you see in kies firmware you didn't found BcmBoot.img or kyleprods.pit for this note i try to flash with full firmware and i success i flash with this firmware with odin 1.85 Download Firmware odin 1.85 this solution success with me in may be 10 pecs Please share if you care and put your result here Regards mMK-DEV |
The Following 24 Users Say Thank You to mMK-DEV For This Useful Post: |
01-16-2015, 16:17 | #3 (permalink) |
No Life Poster Join Date: Aug 2012 Location: MUMBAI-METRO Age: 37
Member: 1800009 Status: Offline Sonork: 100.1654307 Thanks Meter: 806 | Here |
02-13-2015, 19:09 | #8 (permalink) |
No Life Poster Join Date: Aug 2011 Location: Afghanistan
Member: 1646177 Status: Offline Sonork: 100.1604654 Thanks Meter: 369 | As it is new hardware specially its LCD when you flash new hardware with old firmware you will get this problem after flash so you had better flash with latest versions for this model and also this problem can be solved by replacing LCD but we had better solve the problem caused by flashing by Software . WBR |
The Following 2 Users Say Thank You to NKhan_Gsm For This Useful Post: |
02-14-2015, 12:43 | #9 (permalink) |
No Life Poster Join Date: Aug 2010 Location: SearchinG ... Age: 39
Member: 1369772 Status: Offline Thanks Meter: 297 | Last edited by ..::Nokian CareŽ::..; 02-17-2015 at 10:02. Reason: quote removed |
The Following User Says Thank You to maxpro12 For This Useful Post: |
03-10-2015, 11:59 | #10 (permalink) |
Junior Member Join Date: Oct 2014 Location: nepal,narayangadh
Member: 2272184 Status: Offline Thanks Meter: 2 | i have same problem i tried four different flash file but problem not solved please upload file ...thanks |
The Following User Says Thank You to samir_paudel99 For This Useful Post: |
03-28-2015, 09:14 | #12 (permalink) |
No Life Poster Join Date: Jul 2005 Location: France Age: 48
Member: 165812 Status: Offline Sonork: 100:1627635 Thanks Meter: 4,267 | Here are the same firmware version uploaded on 4shared: S7582XXUANG1 Repair Firmware Share If U Care |
The Following User Says Thank You to tsarkh For This Useful Post: |
03-31-2015, 08:26 | #15 (permalink) |
Member: 165812 Status: Offline Sonork: 100:1627635 Thanks Meter: 4,267 | |
The Following 2 Users Say Thank You to tsarkh For This Useful Post: |
