Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
08-26-2017, 21:57 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | S8, how to remove PayJoy, MDM , Demo mode, etc ? cant enable ADB, cant flash custom recovery, cand Factory Reset. is there any way to disable this ? |
The Following User Says Thank You to yurais For This Useful Post: |
11-20-2017, 12:47 | #2 (permalink) |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | I have a similar situation with a Note3 (N900T Tmo) with the PayJoy crap on it. It lets me boot up to the main screen, even able to use it but the PayJoy keeps popping up. I can access download mode via buttons, BUT when trying to flash anything (stock or even factory combination files) it throws an MDM error. Tried every version of Odin including the patched ones, but none can flash anything onto this device. The Developer Options menu is locked so I can't enable ADB mode including via keypad *#0808# The computer can see the device connected, just showing a modem port, no ADB port. Interestingly I'm able to use an OTG cable and pretty much sideload any app on it, but the low level ones get blocked upon running it. Tried all these apps, but no Joy with PayJoy! (pun intended lol) The MDM policy prevents Test-DPC from running. Android_Developer_Options_v2014-08-12.APK Android_Developer_Options_v2015-07-16.APK Apex_Launcher__Android_Does_v3.2.1.APK Cortana__Microsoft_v2015-07-13.APK Developer__Jan_Tursky_v4.5.APK Device_Owner_Provisioner__Cottonwood_Computer_v15. 4.1.APK FRP_Bypass_ADB__GSM_Flasher.ZIP FRP_Bypass__Easy_Firmware_v1.0.APK FRP_Bypass__RJ_v1.0.APK FRP_Remover_ADB_v2017-10-14.ZIP GAM5_v2015-01-01.APK GAM6_v2016-01-01.APK GAM7_v2017-01-01.APK GAM7_v2017-07-01.APK GAM7_v2017-09-01.APK Google_Admin__Google_v2014-10-16.APK Google_Admin__Google_v2016-11-20.APK NFC_Tools_v5.4.APK NFC_Tools__Wakdev_v4.4.APK Samsung_Retail_Mode_v2.0.2.APK Sidebar__Mohammad_Adib_v4.4.0.APK Test_DPC__Sample_v3.0.3.APK Test_DPC__Sample_v4.0.4.APK Test_DPC__Sample_v4.0.5.APK By the way I have also tried an emergency boot disk, which allows download mode, but the dreaded MDM error still shows up. I believe the solution lies in disabling the MDM policy somehow then flash full stock and done. So if anyone has a working solution, at least give us a clue or two, much appreciated. (not interested in private Skype, thanks.) |
03-08-2020, 18:17 | #4 (permalink) |
Junior Member Join Date: Aug 2016 Location: Home
Member: 2618612 Status: Offline Thanks Meter: 2 | I remove payjoy from s8 plus doing this: 1- *#0808# 2- mtp + adb, click and go back and click again on mtp + adb,, 3- adb shell to ask for depuration permission. 4- adb shell pm list packages -e | grep 'payjoy' 5- adb shell pm disable-user --user 0 com.payjoy.status (the one i found on step 4, cant remember exactly) 6- now payjoy is disable, enable oem unlock, do a factory reset or download mode and reflash the combination and stock after that.. whatever you want. |
The Following User Says Thank You to Serge Winters For This Useful Post: |
