Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 01-30-2013, 17:13   #1 (permalink)
Member: 752151
Thanks Meter: 211
Smile Samsung Baseband IMEI problem i9100 n7100 i9250 i9103 solution 100%
Solution 1: Reset EFS via SPT (must serial Number visible)
Solution 2: Check U100 have crack (replace U100 and reballs the baseband IC UCP300)
Solution 3: try this if solution 1,2 not work. (at the picture)
Uploaded with ImageShack.us
The Following 8 Users Say Thank You to tantan167 For This Useful Post:
Old 01-31-2013, 15:59   #2 (permalink)
papoo's Avatar
Member: 188374
Sonork: 1000.2
Thanks Meter: 177
Any One Tested This Solution.
Old 02-02-2013, 09:16   #3 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,358
Yes this hardware solution is tested long time need exchange U100 if not help rehot or reflow UCP300.
The Following User Says Thank You to wgmmmx1 For This Useful Post:
Old 02-04-2013, 09:54   #4 (permalink)
Member: 1418143
Thanks Meter: 341
big thing's anytime's where to get same thing .. where ( phones ) can one get u100 ?
Old 02-04-2013, 15:57   #5 (permalink)
Gsm.Universal's Avatar
Member: 1526738
Sonork: 100.1607644
Thanks Meter: 3,631
i'm try but stil same imei blank not show imei i9100
Old 02-04-2013, 16:17   #6 (permalink)
Member: 1418143
Thanks Meter: 341
hot or replaced U100 ?
Old 02-04-2013, 16:43   #7 (permalink)
Member: 752151
Thanks Meter: 211
if you trying to replace the u100 make sure you can reballs the ucp300 a the back. the 3 solution is work to me. i have alot of i9100 no imei or baseband is done. the ic have a arrow is always shorted that's the reason to replace it.
The Following User Says Thank You to tantan167 For This Useful Post:
Old 03-08-2013, 08:08   #8 (permalink)
..::MobiLinks::..'s Avatar
Member: 614141
Sonork: 100.1618541
Thanks Meter: 21
i have n7100 baseband ok but imei like 04.............. fone is fresh box pack
trying many times to repair it with spt and sgtool but it show msl error on sgtool and timeout in spt as u can see on my thread spt team help[ANSWERED]
Old 03-09-2013, 09:50   #9 (permalink)
Member: 752151
Thanks Meter: 211
1: try to reset efs vis spt box then write n7100 root file.
2: check usb debugging. @cellphone
3: then click spt mode.
4: you need uart micro cable.
5:check repair imei, put imei, then click factory mode.
i'm using SAM UART micro cable from z3x box. but i'm using spt tool for imei repair.
Old 03-09-2013, 14:21   #10 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
Thanks Meter: 18,241
Originally Posted by aryanbaba View Post
mare pass 8 samsung i9100 hai sab main imei aur basband null hai (U100 or UCP30) ki digram post kare
here Service manual
Samsung I9100 Galaxy S2 - Discussion Thread - Last Official firmware
Old 03-09-2013, 14:31   #11 (permalink)
Member: 752151
Thanks Meter: 211
Old 03-11-2013, 09:40   #12 (permalink)
Member: 1834434
Thanks Meter: 9
any solution of samsung s5830 unknown baseband solution
Old 03-12-2013, 20:04   #13 (permalink)
Member: 614141
Sonork: 100.1618541
Thanks Meter: 21
same procedure as mentioned above...........
Old 04-12-2013, 17:28   #14 (permalink)
Member: 68485
i have blank IMEI in i9250, help me!
Old 04-12-2013, 22:04   #15 (permalink)
Member: 1159099
Thanks Meter: 6,353
hi,first need repair baseband and after can repair imei.
check this i9250 unknown badband[ANSWERED]
Page generated in 0.38772 seconds with 7 queries
