Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 02-08-2017, 11:32   #1 (permalink)
Member: 2666993
Samsung g600fy frp unlock solution
How to Samsung g600fy frp unlock solution plz help
I try frp reset file but same problem
Sir any one working solution send
Thank you........
Old 02-08-2017, 11:39   #2 (permalink)
appsworlmardan's Avatar
Member: 2046498
Sonork: 100.1676751
Thanks Meter: 152
Thumbs up which box you flashed it
Thank you........
using of miraclebox+key
is the bet way to reset frp in few second
connect box
select port
reset frp
your problem solved
The Following 2 Users Say Thank You to appsworlmardan For This Useful Post:
Old 02-08-2017, 11:56   #3 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,636
Thank you........
You can Chimera Tool:
Samsung Galaxy On7 Duos
Model: SM-G600FY
Supported features
✓ SW Change
✓ Unlock
✓ Info
✓ Root/Unroot
✓ Network repair
✓ Read / Write certificate
✓ Restore / Store backup
✓ Reset FRP Lock
✓ Reset FRP Lock
✓ Firmware Compatibility
✓ Reset FRP/Reactivation Lock
✓ Reset Screen Lock
https://chimeratool.com/en/models
Or manual solution here:
https://www.youtube.com/watch?v=w3hnC8DLWt8
The Following User Says Thank You to gcceleghg For This Useful Post:
Old 02-08-2017, 12:35   #4 (permalink)
Member: 2666993
connect box
select port
reset frp
your problem solved
Sir miracle box + key use frp reset done then power on mobile same problem
Old 02-08-2017, 13:05   #5 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,636
Dear user!
You can also use this solution:
Samsung G600FY Frp Remove
-Download and flash the boot file through Odin COMBINATION_G600FYXXU1APF1_boot.tar
-This will enable adb.
Run the command to bypass activation
Adb shell content insert --url content: // settings / secure --bind name: s: user_setup_complete --bind value: s: 1
- Turn on oem unlocking and reset.
Last edited by ...:::::NP™:::::...; 08-30-2017 at 13:06. Reason: Download link has been update
The Following 2 Users Say Thank You to gcceleghg For This Useful Post:
Old 02-08-2017, 13:16   #6 (permalink)
Vahidpappali's Avatar
Member: 2602890
Sonork: NOTINSTALLED
Thanks Meter: 200
Re boot to recovery mode check your phones current version
IT SHOW ON TOP
download same version combination file from support (z3x) or search
DONT FLASH WITH LOWER VERSION COMBINATION FILE IT WILL BRICK YOUR SET
IF ITS DONE CLICK FRP RESET
UMT HAVE SUPPORT THIS MODEL TOO TRY IT IF YOU HAVE
The Following User Says Thank You to Vahidpappali For This Useful Post:
Old 02-08-2017, 14:48   #7 (permalink)
Member: 2666993
IT SHOW ON TOP
Sir
VER
G600FY XX U 1BPK1/G600FY ODD1BPK/G600FY XXU1AOL1/G600FY XXU1BPK1
Wich file combination use..... help
Old 02-09-2017, 13:23   #8 (permalink)
Member: 2046498
Sonork: 100.1676751
Thanks Meter: 152
Thumbs up i will unlock frp many phones
using that me uclock many frp
reset again
Old 02-09-2017, 14:01   #9 (permalink)
Member: 2666993
reset again
Sir
Thisver
1 st reset file miracle box suport downlod modem file
2 nd reset frp with miracle box
Then 100% ok power on same problem
Sir
this method use
R/Ro gide me.......... Right method gide me help..... Plz
Old 06-11-2017, 14:48   #10 (permalink)
applestorebd's Avatar
Member: 1659078
Sonork: Mahidi Munna
Thanks Meter: 154
Use Z3x Box And Select Model J700f Then Press Reset FRP/React/EE Just It Wait 10 Minutes
100% Tested Lots Of Deices
The Following 8 Users Say Thank You to applestorebd For This Useful Post:
Old 08-06-2017, 09:09   #11 (permalink)
p.k510's Avatar
Member: 1778370
Sonork: sujan_goa
Thanks Meter: 66
yes sir good work ......... my set reset frp thanks
The Following 2 Users Say Thank You to p.k510 For This Useful Post:
Old 08-06-2017, 10:49   #12 (permalink)
Member: 727810
Sonork: 100.1627301
Thanks Meter: 163
Best Option Select J700F & put phone in download mode & reset frp 100% tested
The Following 2 Users Say Thank You to max_cool For This Useful Post:
Old 08-12-2017, 08:14   #13 (permalink)
Member: 2706892
Thanks Meter: 3
its 100% working
lots of thanks bro
The Following User Says Thank You to anandmr4 For This Useful Post:
Old 08-30-2017, 10:06   #14 (permalink)
Member: 1478562
Thanks Meter: 40
2017 new security method
just follow this video.... you'll bypass google account..
http://www.youtube.com/watch?v=M-4yHjPCTxw
Old 08-30-2017, 11:01   #15 (permalink)
Member: 2752376
Thanks Meter: 10
Salam, your connection with info has no connection..
The Following User Says Thank You to aliackbarr For This Useful Post:
Page generated in 0.37283 seconds with 7 queries
