Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
11-20-2016, 21:02 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: India [UNKNOWN]
Member: 1143809 Status: Offline Sonork: 100.1602432 Thanks Meter: 574 | Samsung g610f frp solution needed If anyone have combination file pl upload |
The Following User Says Thank You to MOHIT_THAREJA For This Useful Post: |
11-26-2016, 05:37 | #3 (permalink) |
No Life Poster Join Date: Apr 2005 Location: brunei
Member: 141262 Status: Offline Thanks Meter: 348 | what is the status now can you give a image of the phone.. we got alot of solution here on gsmhosting try to search even it is not the same model but it can be fix with the same procedure... |
11-26-2016, 06:33 | #4 (permalink) | |
No Life Poster Join Date: Sep 2015 Location: Everywhere Age: 29
Member: 2454192 Status: Offline Sonork: 100.1674433 Thanks Meter: 693 | Quote:
2.Download and copy com.rootjunky.frpbypass-1.0.apk to the device micro sdcard or download once into the device. 3.Start phone and connect to WIFI also plug into the computer with your usb cable. 4.Start RealTerm on your pc and under pisplay check the box HALF DUPLEX 5.Right click on my computer and select manage once it opens click device manager then modems 6.Under modems you should see a Samsung device. right click it then select properties 7.Once the properties window opens select modem tab and see what port it is on like com5 for an example 8.Now that you know the com port number close all device manager windows and open RealTerm again 9.Under the ports tab in RealTerm enter your port number then click change. 10.Next, click the send tab. you will need to send these two commands with the Send ASCII button 11.First at+creg?\r\n 12.Then atd1234;\r\n 13.Look at your phone and the dailer will pop up 14.click on massege then write Google in sms | |
The Following 3 Users Say Thank You to Asad ali khan For This Useful Post: |
