Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 10-07-2017, 12:19   #1 (permalink)
Member: 76522
Thanks Meter: 30
Samsung G900v reactivation lock how to remove?
I have such phone with reactivation lock on. I get root and dev bootloader, but no way to downgrade it to 4.4 Android only with 5.0 and higher it work. How to find Samsung Account to tis model?
Old 01-12-2018, 18:56   #2 (permalink)
Member: 2526783
Thanks Meter: 22
there is no "oem unlock" for this device. I have the same issue. i can't find anything that will reset the samsung account.
Old 01-13-2018, 06:13   #3 (permalink)
Member: 2107306
Thanks Meter: 612
I have done it on 5.1.1. Flash combination with same rollback bit protection. Install this apk:
samsung-account-1.6-com.osp.app.signin_1.6.008_minAPI9(nodpi).apk
The you can add your samsung account. Go back to stock on 5.1.1 and add your previously samsung account. Tested by me on many S5, note4 etc... For sure tested on g900v.
The Following 2 Users Say Thank You to Prsctt For This Useful Post:
Old 01-24-2018, 00:21   #4 (permalink)
Member: 2592628
Thanks Meter: 212
easier solution
an easier solution exists. I had a 6.0.1 g900v I could not remove Reactivation lock from, called in another tech, he was able to do it remotely through download mode. took seconds.
No idea what file he used as it was done through redirector.
Old 01-24-2018, 01:32   #5 (permalink)
Member: 2107306
Thanks Meter: 612
Most likely engroot or combination flashed, and then gcpro REMOVE_EE or whatever option I don't remember.
Page generated in 0.16014 seconds with 8 queries
