Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
02-09-2015, 10:01 | #17 (permalink) |
Junior Member Join Date: Feb 2015
Member: 2341406 Status: Offline Thanks Meter: 1 | ok. I've flashed the MK6 firmware, however its coming up on my display that google play has stopped responding. now for rooting after its all sorted will i be able to remove the rooting and keep my IMEI number. and what rooting should i use? I've fixed the google play not responding being displayed just by doing a factory reset . i will await further instructions from you |
02-09-2015, 10:30 | #21 (permalink) |
Freak Poster Join Date: Mar 2008 Location: Kuwait
Member: 735013 Status: Offline Thanks Meter: 74 | Mate, this process is trial and error, if we can restore back the original imei because I encountered same issue already which I applied this method and I got it working. BUT, not all can be restored back in this process in which, you may now be needing a box to rewrite the imei. Now, about your question, you can just full unroot your device without flashing (SuperUser). |
02-09-2015, 10:51 | #25 (permalink) |
Member: 735013 Status: Offline Thanks Meter: 74 | Nop, flash this one first. EDIT: Ooops,sorry..you have a custom rom already right? Btw, your imei is still 004 right? |
02-09-2015, 10:54 | #26 (permalink) |
Member: 2341406 Status: Offline Thanks Meter: 1 | that's flashed in my phone ready.. i do appreciate your help... I'm having to use a crap phone atm and i miss using whatsapp and yep my IMEI is still that Last edited by darren100; 02-09-2015 at 11:00. |
