Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 11-22-2014, 17:09   #1 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Samsung Galaxy Mega I9200 After update touch not working Solution Here Tested
Guide: MySelf
This Solution Tested & Done By : allumts
Note: This file Only fix Bootloop issues Always Booting in
recovery mode, after update to 4.4.2 hang Logo
Only recovery mode & Touch not working after update to kitkat.
Tested Downgrade from 4.4.2 to 4.2.2 Tested vit out any issues
Firmware Flashing Method:
* Put Mobile in Download Mode By Holding Vol dwn + Home + Pwr
* Cnnt vit pc using Usb
* Run Odin
* Select File in PDA
* Uncheck Auto Boot in Odin (Important This Step )
* Click Start
* After Flash complete remain with Blu line, but not import after PASS only Important.
Just take out battery, wait 30 sec.s and
put back the battery power on phone,
itself goes in Recovery mode, or manually put recovery mode just
select Wipe/Factory reset and reboot, all working fine.
Note:Tested nd Worked Fine nd IMEI also fine
Firmware Download Here Android 4.2.2
Mirror Link Here Login vit sammobile Acc
Odin Flasher
Note:if all language not available aftr flash simply root yur device install language enabler frm here nd enable all languages reboot device
Also yu can install all language manually via wifi Goto settings /Language input
CSC flashable Language Pack vil be added Soon
Result Credits to : allumts
Odin flash Log
 Added!!
 Enter CS for MD5..
 Check MD5.. Do not unplug the cable..
 Please wait..
 I9200ZTUCNG1_I9200ZZTCNG1_I9200ZTUCNG1_HOME.tar.md  5 is valid.
 Checking MD5 finished Sucessfully..
 Leave CS..
 Odin v.3 engine (ID:18)..
 File analysis..
 SetupConnection..
 Initialzation..
 Get PIT for mapping..
 Firmware update start..
 SingleDownload.
 sbl1.mbn
 NAND Write Start!!
 sbl2.mbn
 sbl3.mbn
 rpm.mbn
 aboot.mbn
 tz.mbn
 boot.img
 recovery.img
 system.img.ext4
 NON-HLOS.bin
 cache.img.ext4
 hidden.img.ext4
 RQT_CLOSE !!
 RES OK !!
 Remain Port ....  0
All threads completed. (succeed 1 / failed 0)
DON'T SAY THANKSJUST PRESS BUTTON
BUTTON
The Following 22 Users Say Thank You to jamesjerss For This Useful Post:
Old 11-28-2014, 14:58   #2 (permalink)
I_PHONE's Avatar
Member: 1579234
Sonork: Not user
Thanks Meter: 342
bro Tach Workng But Imei
Galaxy Mega I9200 imei 0/01
help me
The Following User Says Thank You to I_PHONE For This Useful Post:
Old 11-28-2014, 15:01   #3 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
help me
Did yu reset the efs using software box before downgrade
james
The Following User Says Thank You to jamesjerss For This Useful Post:
Old 11-30-2014, 09:26   #4 (permalink)
Member: 2163831
didn't work in my phone .. flashing fails...
The Following User Says Thank You to rupeshch For This Useful Post:
Old 11-30-2014, 10:22   #5 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Post yur screen shot vit error . mayb yu hav othr issues
james
Sent from my SM-G900F using Tapatalk
Old 11-30-2014, 15:38   #6 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
help me
Loock Log of odin above and photo of my I9200 Touch full working after easy Downgrade with this Fw.
I not have select "Autoreboot" in odin It's Important, flash goes fine, have take out battery for 20/30 second then entered in Recovery Mode done Wipa/Facory reset and phone was botting w/o any issue with his Imei, all perfectament working.
Read carefully all steps, my phoe was to 4.2.2 KK fw _SER p.code, repaired with 100% success
allumts
Old 12-17-2014, 20:16   #7 (permalink)
Member: 712843
Thanks Meter: 15
Galaxy Mega I9200 imei ok
help me no network
Old 12-17-2014, 20:23   #8 (permalink)
allumts's Avatar
Member: 1564612
help me no network
What want to say with Imei OK but network no?, have changed or restored Original?, post what have done for this Imei
allumts
The Following User Says Thank You to allumts For This Useful Post:
Old 12-18-2014, 16:12   #9 (permalink)
Member: 712843
Thanks Meter: 15
thx
it was hardware problem
Old 12-18-2014, 20:36   #10 (permalink)
allumts's Avatar
Member: 1564612
thx
Please let know to all what was hardware issue?, it's very strange that you repair all and only no network for Hw issue...what the problem?
Old 01-17-2015, 01:16   #11 (permalink)
cooloxf's Avatar
Member: 120893
Thanks Meter: 69
what about i9205 touch screen not working in 4.4.2 and no wifi no imei in 4.2.2
Old 01-17-2015, 20:56   #12 (permalink)
allumts's Avatar
Member: 1564612
Have just repaired one in this moment, i'm tired now but in these day i will be a good and easy guide for restore Touch not working or Bootloop in Galaxy Mega GT-I9205, are only 3 steps and all turn back working 100% also imei and Baseband
allumts
Old 01-20-2015, 10:28   #13 (permalink)
allumts's Avatar
Member: 1564612
For you and all, Tested 100% solution also for GALAXY MEGA LTE I9205, NO TOUCH AFTER UPDATE or BOOTLOOP HERE:
guide-galaxy-mega-i9205-4-4-2-4-4-4-no-touch-bootloop-after-update-100-fix
allumts
Old 02-27-2015, 10:22   #14 (permalink)
unlockmachine44's Avatar
Member: 1350724
Thanks Meter: 188
hi
can you plz post anther download link??
this server takes about 8 hours to download
thanks
Old 02-27-2015, 10:35   #15 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Originally Posted by unlockmachine44 View Post
hi
thanks
Download taiwan country firmware from sammobile
The Following 2 Users Say Thank You to jamesjerss For This Useful Post:
Page generated in 0.30950 seconds with 8 queries
