Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
05-22-2017, 16:31 | #1 (permalink) |
Freak Poster Join Date: Dec 2015 Location: nigeria .benin
Member: 2495283 Status: Offline Sonork: gsmvilla.com Thanks Meter: 12 | Samsung Galaxy Note 4 (SM-N910F) can't flash firmware Hello guys pls how do I fix this Samsung.. can't flash...sometimes power on.. sometimes can't power on Sent from my iPhone using Tapatalk Pro Last edited by ...:::::NP™:::::...; 05-23-2017 at 22:50. Reason: Image resize |
05-22-2017, 17:01 | #5 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Hi, Try with Kies or smart switch by S/N , reason security boot has been enabled.
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
05-22-2017, 17:11 | #7 (permalink) | |
Member: 2495283 Status: Offline Sonork: gsmvilla.com Thanks Meter: 12 | Quote:
How do ⓝ u mean by smart switch by S/N Sent from my iPhone using Tapatalk Pro | |
05-22-2017, 17:12 | #8 (permalink) |
Insane Poster Join Date: Oct 2015 Location: Bosnia and Herzegovina
Member: 2475433 Status: Offline Thanks Meter: 9 | It can be hardware faulty..try as he said with smartswitch..or you can try to heat a little bit motherboard and then try odin flash. Sent from my SM-G950F using Tapatalk |
The Following User Says Thank You to gamerz064 For This Useful Post: |
05-22-2017, 17:20 | #9 (permalink) | |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Quote:
must read this sticky thread, inside has full guide. http://forum.gsmhosting.com/vbb/f777...datas-1986895/
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. | |
05-22-2017, 19:18 | #11 (permalink) |
No Life Poster Join Date: Jan 2013 Location: lebanon
Member: 1869842 Status: Offline Sonork: 100.1625473 Thanks Meter: 186 | 1-Flash with 4 files repairing firmware using a pit file as well 2-if your problem still after flashing repair emmc using z3x jtag box 3-if no solution after trying to repair emmc with z3x jtag box you will have to change emmc ic You need a ddl file or a boot file to flash the phone with before trying the 3 steps I have told you to do it. |
The Following User Says Thank You to habibboxes For This Useful Post: |
05-23-2017, 22:46 | #13 (permalink) |
Member: 2495283 Status: Offline Sonork: gsmvilla.com Thanks Meter: 12 | Note edge n915f Cannot power on..I reheat pcb and flash .. phone works well. After 15 mins phone went dead again can't power on and I have tried everything thing not working... pls guys any solution Sent from my iPhone using Tapatalk Pro |
05-23-2017, 23:06 | #14 (permalink) | |
Member: 2475433 Status: Offline Thanks Meter: 9 | Quote:
Sent from my SM-G950F using Tapatalk | |
