Samsung Galaxy S III mini hard reset Before you buy a new cell phone or new tablet, please try the following procedure to repair your device. First charge your battery, backup your important data if possible and in most cases take out SIM and SD card. It is impossible to recover your data after doing a hard reset, so online backup is always important. You can also backup your data on your hard drive or a raid system. http://up.top4top.net/uploads/2012/1...6435e7fc11.jpg Samsung Galaxy S III mini hard reset force reset Reset the device (press and hold POWER button for 8-10 seconds) Unlock Galaxy S3 mini using hard reset sgs3 mini hard reset or reset Galaxy S3 mini: PRESS AND HOLD VOLUME UP + Home Button + Power Turn the phone off. Press and hold VOLUME UP and Home(center) button Press Power until the phone vibrate Wait until you see the Android logo then release all the buttons. Select Wipe data/Factory reset with VOLUME DOWN, press Power (right hand-side) Select YES -- delete all user data with VOLUME DOWN and then press Power After format, press Power again to reboot phone. (select reboot system now) or If your device is frozen and unresponsive, press and hold http://www.hard-reset.com/images/sam...ard_reset1.png for 8-10 seconds. The device will reboot automatically. If this does not solve the problem, perform a factory data reset. In Idle mode, open the application list and select Settings → Back up and reset→ Factory data reset → Reset device→ Delete all. or Factory format entering sgs3 mini format code Use this method to hard reset your Samsung Galaxy S III mini: Enter *2767*3855#. Warning! All your data including contacts, messages etc. will be lost! Copy all your necessary data/Contacts/Messages etc. to SIM or make backup to your PC before full reset! Take out SIM card before full reset. Note: If you reset your device to the factory defaults with SD card encryption setting enabled, the device will not be able to read your encrypted files. Disable this setting before resetting the device. sgs3 firmware flash download mode: PRESS AND HOLD VOLUME down + Home Button + Power on unlock gs3 mini, how to reset S3 mini, sgs3 mini reset, http://forum.gsmhosting.com/vbb/imag...c/gsmforum.jpg |
