Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
11-11-2014, 07:40 | #1 (permalink) | |
No Life Poster Join Date: Mar 2012 Location: gsm world
Member: 1741973 Status: Offline Thanks Meter: 115 | Samsung Galaxy S3 hang on logo not solve logs of teraterm boot card repair Quote:
how to fix this s3 problem logo only odin mode no any error like no product name recovery mode can enter but they cant wipe factory E cant mount failed to format cant flash via z3x,octopus, odin... all is failed i need some advice and answer if this trouble can fix by z3x easy jtag or it is a dammage EMMC chip not like this txt showing E:failed to mount.. invalid arguement that so called EFS problem. | |
11-11-2014, 08:28 | #3 (permalink) | |
Freak Poster Join Date: Jul 2010 Location: Dharmapuri,Tamilnadu
Member: 1343981 Status: Offline Thanks Meter: 30 | Re Write Efs Dear Bro After Complete Tera Term Process, Go To The 2nd Step > Write Efs File Then Update Full Software Efs & Pitr File Link In there I9300 EFS & PIT - Download - 4shared - Satcom Singaram After U Need To Write Ur Imei Via Z3x Regards SingaraVelan [email protected] Quote:
The Following User Says Thank You to SatcomSingaram For This Useful Post: |
11-11-2014, 08:57 | #4 (permalink) |
Member: 1741973 Status: Offline Thanks Meter: 115 | thats the point i cant flash the phone in odin or both samsung tool box... after i used terraterm nothing happened just not like the image of a white screen and a reverse logo of android in downloading mode. the problem is not an E: failed to mount invalid arguement... the phone can enter odin download mode, can enter recovery mode but failed in wiping. ive allready tried 2 different firmware, firmware that i test for other phone earlier. i want to try write EFS as u given bro.. i confused why my logs is different compare to the logs ive seen here and to other search engine |
11-11-2014, 09:33 | #6 (permalink) |
Member: 1741973 Status: Offline Thanks Meter: 115 | <ID:0/042> Added!! <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> I9300_Repair_efs.tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/042> Odin v.3 engine (ID:42).. <ID:0/042> File analysis.. <ID:0/042> SetupConnection.. <ID:0/042> Initialzation.. <ID:0/042> Set PIT file.. <ID:0/042> DO NOT TURN OFF TARGET!! <ID:0/042> Get PIT for mapping.. when pit file is put this is the result, seems they cant do a partition almost take too long maybe an half hour or more |
11-11-2014, 13:11 | #7 (permalink) |
Banned Join Date: Oct 2014 Age: 29
Member: 2278142 Status: Offline Sonork: 100.1623070 Thanks Meter: 15 | Bro hard reset phone you problem solved voloum up+home+power button if you show recovery option then press voloum down wipe data cache / factory reset press power if you show maney option option 1-no option2-yes delet all data chose option 2 and press power button them rebot phone now option press power switch them your phone is restart your problem is solved click thanx button regards by abhayrana |
11-18-2014, 07:34 | #8 (permalink) | |
Member: 1741973 Status: Offline Thanks Meter: 115 | s3 still cant flash and suspected as a dammage EMMC CHIP Quote:
E: faile to format user data E: failed to format cache E: failed to mount storage always failed in recovery mode option phone doesnt format/wipe/factory reset | |
