Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
05-22-2013, 02:37 | #16 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: Gujrat (India) Age: 38
Member: 253882 Status: Offline Sonork: 100.1585698 Thanks Meter: 242 | Quote:
And one more time i535 is not lock phone so why u try to unlock??? | |
06-02-2013, 04:58 | #18 (permalink) |
Freak Poster Join Date: Sep 2011 Location: venezuela Age: 37
Member: 1656305 Status: Offline Sonork: 100.1624503 Thanks Meter: 48 | same here the same here... everything's fine with my i535.. but only works on EDGE.. not 3G... what can I do?... im using stock 4.1.2... thanks... |
06-05-2013, 14:14 | #19 (permalink) | |
Using Titanium Backup, an app called Setup wizard 1.0 uninstall it and that should remove the notification `NON-VERIZON SIM`) (2) for calling u just need to (Press Press *#22745927 "Enable/Disable Hidden Menu" comes up Select "Enable" on the popup, Press *#2263# GSM Band Preference and select Your network band wait few second for network and then try to make call) | |
06-05-2013, 18:37 | #20 (permalink) |
No Life Poster Join Date: Aug 2011 Location: caribbean island
Member: 1643797 Status: Offline Thanks Meter: 182 | for me apn don't work when go to titanium back and then apn manager pro long press then convert to user app . after finish all this and now open apn manager pro now see swap apn insert apn backup & restore manage animations now i seclet ( insert apn ) after put new apn of my network i get this erro problem while creating APN. not sure what i'm doing wrong phone is already rooted |
06-18-2013, 03:57 | #21 (permalink) |
Junior Member Join Date: Mar 2013
Member: 1892989 Status: Offline Thanks Meter: 6 | unlock d0ne with this method but i have a big problem in my phone every 2 or 3das later i cannt send call phone show com.application error but incoming and massage ok after reset phn and unlock again all ok have any id for me?(i use 2g sim) thanks |
07-12-2013, 21:41 | #24 (permalink) |
Freak Poster Join Date: Nov 2008 Location: Indonesia
Member: 901949 Status: Offline Thanks Meter: 50 | it's not working for the root method, you have to use another rooting method and i get it here ... DroidViews | Root and Install CWM Recovery on Verizon Galaxy S3 SCH-I535 Android 4.1.1/4.1.2 for the other steps it seems to works fine with me, thanks msmobile |
11-28-2013, 22:50 | #28 (permalink) |
Insane Poster Join Date: Sep 2006 Location: Lahore
Member: 342371 Status: Offline Thanks Meter: 73 | Dear msmobile thanx for share unlock s3 i535 your method and instruction are very easy i do 10 phone unlock by your method 100% ok GSM service on in pakistan |
The Following User Says Thank You to imranali2cool For This Useful Post: |
12-03-2013, 03:36 | #29 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2077328 Status: Offline Thanks Meter: 0 | Good info here I like the info.. however, my problem is huge for my phone... And now the neverending quest is revealed... The real question:: How can I enable 1700mhz on this phone??? Verizon put a block against it, and there are rewards for the one who discovers how to break it... (xda) So any ideas how to get 3g 1700mhz working??? |
12-06-2013, 14:51 | #30 (permalink) | ||
samsung meid repair - Download - 4shared | ||
