Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
06-13-2017, 07:42 | #1 (permalink) |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,640 | Samsung Galaxy S8/S8+ [EXYNOS CHIP][ROOT][SOLUTION] Supported model: Galaxy S8 SM-G950F SM-G950FD SM-G950L SM-G950N Galaxy S8 + SM-G955F SM-G955FD SM-G955L SM-G955N Download TWRP for Galaxy S8 Download TWRP for Galaxy S8 + Download Root File Here Procedure : 1.Activate developer mode by tapping 5 times on the Build number in Settings -> Device Information Activate Oem Unlock. 2.Download the Root Magisk file in the link Above. 3.Copy Magisk Root and put it into internal memory. 4.Download TWRP for Galaxy S8 or S8 +. 5.Proceed to Download Mode by turning it off and then holding down the 3 keys. Source + Home + Vol (-) -> Select Continues. 6.Open Odin to select AP and path to twrp .tar file. 7.Click Start to start the flash. 8. Put in recovery mode by turning it off and holding down the 3 power keys. Power + Home + Vol (+). 9.In TWRP you choose Install, select the Magisk file to install. 10.The installation process is over, select reboot system to reboot. S8 twrp-3.1.0-1-dreamlte.img.tar S8+ twrp-3.1.0-1-dream2lte.img.tar Root File: Magisk_Root_Android_Nougat_Datdevs.zip or Download From :- no-verity-opt-encrypt Sent from my VFD 200 using Tapatalk Last edited by ...:::::NP™:::::...; 06-13-2017 at 10:03. Reason: Download link added |
The Following 8 Users Say Thank You to yuranc8 For This Useful Post: |
06-20-2017, 08:17 | #5 (permalink) |
Member: 2680008 Status: Offline Thanks Meter: 1,640 | I see that ur device havê FRP lock... First Flash with a new and clean OS then remove frp lock after that u can try and post here Sent from my VFD 200 using Tapatalk |
05-20-2019, 08:10 | #12 (permalink) |
Banned Join Date: May 2019 Location: hongkong
Member: 2908813 Status: Offline Thanks Meter: 1 | Most of people use TWRP to root Samsung,you could refer to it. Step 1. Download the corresponding TWRP version and "dm-varity and force encryption disabler" to your Android device. Step 2. Extract the "Odin software" on your computer and launch it. Switch off your Samsung device and boot it into Download Mode by pressing and holding the "Bixby + Volume Up + Power" button for 10-15 seconds. Step 3. Connect your Samsung phone to computer with USB cable, then it will be detected. Step 4. Turn on the Odin software, and you'll see an interface like below. Click on the "AP" button and choose "TWRP recovery" that you've installed before. |
09-16-2019, 05:53 | #13 (permalink) |
Freak Poster Join Date: Oct 2014 Location: Arusha,Tanzania
Member: 2267293 Status: Offline Thanks Meter: 79 | STEPS TO ROOT SM-G950F Android 9 Binary 5 ----------------------------------------- 1.Make sure you enable OEM unlock if available in Developer Options menu or otherwise follow the video to make it available and then turn it of and on. 2.Flash TWRP recovery and then Flash -->1-no-verity-opt-encrypt-6.0 -->2-RMM-State_Bypass_Mesa_v2 -->3-Magisk-v19.3 3.After rebooting the phone you may have no magisk installed even though you flashed it through the TWRP Recovery, so you just have to re-install it manually by installing the APK Version. ===> MagiskManager-v7.3.2 4.The phone is now rooted and incase you want to repair network then you have to flash the modem... ===>combination_modem_G950FXXU5ASF1 Everything is included in the download. https://drive.google.com/file/d/12wU...ew?usp=sharing Thanks... |
The Following User Says Thank You to madcom5 For This Useful Post: |
