Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
02-23-2015, 15:14 | #16 (permalink) |
Freak Poster Join Date: Mar 2008
Member: 730798 Status: Offline Thanks Meter: 48 | IF you connect stuck on Samsung Logo any samsung device to UART TO USB converter and start listening logs, u able to see what exact SW version installed on it. Android Bootloader - UART_DM Initialized!!! [fuelgauge] init_fuel_gauge: battery type = 1 [fuelgauge] init_fuel_gauge: fg_reset_soc = 0 [fuelgauge] init_fuel_gauge: vcell=3920, soc=73, ocv=4051 MODEL_NAME:{{SM-G900F}} eMMC_SERIAL_NUMBER:{{11010048313647453208e5a9ab1c4 100}} BOOTLOADER VERSION : G900FXXU1BOA3 Get DATA success. Get DATA success. check_pit_integrity: invalid pit magic code.(0x0) AST_POWERON |
The Following User Says Thank You to exprxp For This Useful Post: |
06-20-2016, 22:13 | #19 (permalink) | |
Freak Poster Join Date: Mar 2015 Location: Nairobi
Member: 2358876 Status: Offline Thanks Meter: 78 | How to find samsung country origin Quote:
USE IMEI International Numbering Plans, © 2001-2016 COUNTRY CODE Find Out Galaxy Smartphone Country Of Origin From IMEI Code | Tutorials will get the IMEI number of your Galaxy Smartphone. Alternately you can find your phone's IMEI number under your mobile phone battery also. IMEI number is a 15 digit number like the one shown below; Find Out Galaxy Smartphone Country Of Origin From IMEI Code The 7th and 8th number of the IMEI represents the country of origin of that particular Galaxy Smartphone. Here we can see that 1 and 3 are the 7th and 8th numbers. The number 13 stands for the country Azerbaijan, so this device is made in Azerbaijan. Like that each country has different codes. Please find all the available codes which represents each country of origin below; * The numbers 05 or 50 indicates that your galaxy smartphone is manufactured either in Brazil, USA or Finland. * The numbers 08 or 80 indicates that your galaxy smartphone is manufactured in Germany. * The numbers 00 indicates that your galaxy smartphone is manufactured in the Original Factory. * The numbers 01 or 10 indicates that your galaxy smartphone is manufactured in Finland. * The numbers are 02 or 20 indicates that your galaxy smartphone is assembled in UAE or India * The numbers 03 or 30 indicates that your phone is made in China. * The numbers 04 or 40 indicates that your phone is made in China. * The numbers 06 or 60 indicates that your galaxy smartphone is manufactured either in Hong Kong, China or Mexico. * The numbers 13 indicates that your galaxy smartphone is manufactured either in Azerbaijan | |
The Following User Says Thank You to Siroartz For This Useful Post: |
06-28-2017, 23:58 | #20 (permalink) | |
Freak Poster Join Date: Nov 2007 Location: Azerbaijan
Member: 622715 Status: Offline Thanks Meter: 82 | Quote:
06-29-2017, 03:29 | #21 (permalink) | |
Freak Poster Join Date: Jun 2017 Location: Garden Grove, Ca U.S.A. Age: 49
Member: 2723959 Status: Offline Thanks Meter: 49 | Firmware for your GT-I9505 Quote:
You need to download the BINARY (4Files) to REPAIR this issue! ( PM messsage SENT) This occurs because the software and security are not correct! NOW....You live in Macedonia??? if you look on this website...you can find the CSC or CODE you need for your software...Which is VIM... I used SamFirm with this information to download the BINARY Files (4Files) for your device! NOW...to REPAIR you must load the 4 files into there matching slots in Odin...for yours i recommend ODIN v3.09 or above.... once you complete loading the files, please select these OPTIONS: Auto-reboot NAND Erase All Re-Partition (DO NOT USE .pit!! It is already located inside the CSC file!!) F. Reset Time Phone Bootloader Update Phone EFS Clear (You MUST do this...in order to change CSC correctly..and fix MODEM) Once this is done....Connect your device to the computer DIRECTLY! IF the Kies (Computer + Phone) Damaged screen is on the device, Just turn the phone on normal and if that is the screen that shows...then FLASH on that screen!! HIT START! PHONE REPAIRED!!! | |
The Following User Says Thank You to X_KaosMaster_X For This Useful Post: |
06-29-2017, 03:48 | #22 (permalink) |
Member: 2723959 Status: Offline Thanks Meter: 49 | Find REGION Code If your looking for which software to load on the device...being stock What you want to do is go into Samsung Smart Switch. Then Click on the MORE Button. (Upper Right corner of program window) SELECT "Emergency Firmware Recovery and Initialization" SELECT "Device Initialization" Tab at TOP. Then Type in the Device Model NUmber. HIT SEARCH Then Type in the Device Serial NUmber HIT ~OK~ It will tell you your "Code" after you SELECT ~OK~ button.....on the screen that says what it will do to your device. IF you're simply looking for the right code for your REGION...then go here: UPDATO Firmware Downloads Then enter your device MODEL. Then look under the "Filters" for your COUNTRY. it will show you the "CODES" for your REGION. HOPE this HELPS!!! |
08-25-2017, 07:02 | #23 (permalink) | |
No Life Poster Join Date: Oct 2009 Location: Rajasthan INDIA
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | Quote:
Sorry Sir But I Have Samsung SM-J200G With Hang On LOGO Wit FRP ON & I Was Try Write Many Combination & Main Firmware But Again-10 Failed During Write Flash ( Special Boot.img Failed ) Finally i saw your Thread But Your Method Not Working Not Both Smart Switch & Samsung Kies 3 Model:Samsung SM-J200G/DD S/N:RZ8J7283VFY Every Time Both Software Saying model & s/n Wrong Image Bellow Please Help Me. Thanks & regards By: All TECH 4 You | |
