Samsung Galaxy W / GT-I8150 Recovery Mode / Hard Reset While switched off, keep the following buttons pressed. Release the power-button once the Samsung Galaxy W(I8150) is switched on and keep pressing the Home- and Volume Up-button. http://img90.imageshack.us/img90/5254/i8150.jpg As soon as you see the Android with the box, release the Home- and Volume Up-button............................................ ...................... http://img833.imageshack.us/img833/5254/i8150.jpg After you hit the menu-button shown on the last image, the screen will gray out, you will have to wait until the recovery menu appears. -reboot system now Reboots the system. -apply sdcard:update.zip Install diverse updates like themes, custom roms etc. -wipe data/factory reset Deletes all the apps, data and system settings(Files on the external SD-card will stay untouched) -wipe cache partition Only wipes (formats) /cache partition (sometimes used as temp storage for updates, market downloads, etc) it hasn't anything common with Dalvik-cache which is in /data by default and it implies that the following boot after wiping cache partition will not be any longer than usually. (Mosleuddin Saifu).................................... |
gt-I8150 hard reset thanks bro it helps a lot i thought not going to bios only logo kc |
still same after hard reset |
i8150 Quote:
home button to enter recovery menu |
samsung hard reset done first press hold vol+ & menu just one touch power on button no hold few secons open anriod mode then vol- pres & home key open hard reset 100% i try |
100% tested press the menu key then press back button |
thankssssssssssss man good work tested |
Hi! Please, help me :( I have forgot the screenlock pin. I wanna do a factory reset but I can't because asking for a pin code (I suppose it's the same as the screenlock pin) What can I do now ? Thanks in advance! |
Please, delete the previous post. Reason: Missing details! ========================== Hi! Please, help me :( I have forgot the screenlock pin. I wanna do a factory reset but I can't because asking for a pin code (I suppose it's the same as the screenlock pin) I have installed CWM recovery 6.0.5.1. When I select "wipe data/factory reset" it isn't asking for password anymore but it gave me an error. "Can't mount data/... Can't format data/" So, I can't do a factory reset. What can I do now ? Thanks in advance! |
