Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 06-12-2013, 11:01   #1 (permalink)
Member: 1730078
Sonork: 165137:saifu
Thanks Meter: 9
Samsung Galaxy W / GT-I8150 Recovery Mode / Hard Reset
While switched off, keep the following buttons pressed. Release the power-button once the Samsung Galaxy W(I8150) is switched on and keep pressing the Home- and Volume Up-button.
As soon as you see the Android with the box, release the Home- and Volume Up-button............................................ ......................
After you hit the menu-button shown on the last image, the screen will gray out, you will have to wait until the recovery menu appears.
-reboot system now
Reboots the system.
-apply sdcard:update.zip
Install diverse updates like themes, custom roms etc.
-wipe data/factory reset
Deletes all the apps, data and system settings(Files on the external SD-card will stay untouched)
-wipe cache partition
Only wipes (formats) /cache partition (sometimes used as temp storage for updates, market downloads, etc) it hasn't anything common with Dalvik-cache which is in /data by default and it implies that the following boot after wiping cache partition will not be any longer than usually.
(Mosleuddin Saifu)....................................
The Following User Says Thank You to sha. For This Useful Post:
Old 08-29-2013, 05:26   #2 (permalink)
Member: 1688835
Thanks Meter: 2
gt-I8150 hard reset
thanks bro it helps a lot i thought not going to bios only logo kc
Old 11-23-2013, 12:05   #3 (permalink)
Member: 1755479
still same after hard reset
The Following User Says Thank You to nuwan610 For This Useful Post:
Old 01-14-2014, 09:16   #4 (permalink)
nathan111284's Avatar
Member: 1370010
Thanks Meter: 53
i8150
-reboot system now
Reboots the system.
not working for me...
home button to enter recovery menu
The Following 3 Users Say Thank You to nathan111284 For This Useful Post:
Old 01-18-2014, 18:19   #5 (permalink)
Member: 1178113
Thanks Meter: 43
samsung hard reset done first press hold vol+ & menu just one touch power on button no hold few secons open anriod mode then vol- pres & home key open hard reset 100% i try
The Following User Says Thank You to s.v mobiles For This Useful Post:
Old 03-02-2014, 07:28   #6 (permalink)
phudzgsm2010's Avatar
Member: 1351276
Thanks Meter: 37
100% tested press the menu key then press back button
The Following User Says Thank You to phudzgsm2010 For This Useful Post:
Old 01-12-2015, 12:33   #7 (permalink)
ecs_lk's Avatar
Member: 358337
Thanks Meter: 43
-reboot system now
Reboots the system.
it works tested.............
Old 05-03-2015, 09:47   #8 (permalink)
PAKFAN's Avatar
Member: 424731
Sonork: 100.1669530
Thanks Meter: 18
thankssssssssssss man good work tested
Old 05-31-2015, 18:44   #9 (permalink)
Member: 2074507
Hi!
Please, help me
I have forgot the screenlock pin. I wanna do a factory reset but I can't because asking for a pin code (I suppose it's the same as the screenlock pin)
What can I do now ?
Thanks in advance!
Old 05-31-2015, 19:01   #10 (permalink)
Member: 2074507
Please, delete the previous post.
Reason: Missing details!
Hi!
Please, help me
I have installed CWM recovery 6.0.5.1. When I select "wipe data/factory reset" it isn't asking for password anymore but it gave me an error. "Can't mount data/... Can't format data/"
So, I can't do a factory reset.
What can I do now ?
Thanks in advance!
Old 07-03-2015, 06:51   #11 (permalink)
Member: 437074
Sonork: 100.1604517
Thanks Meter: 18
-reboot system now
Reboots the system.
thanks brother 100% working
Page generated in 0.31875 seconds with 7 queries
