Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 09-19-2014, 20:08   #1 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
Samsung GT-I9200 AFTER OTA UPDATE TOUCH NOT WORK ????
Hello, is entered in my shop this I9200 with Touch Working 100%, only Glass and Touch damaged, have replaced this Touch+Glass with new one and Update with Ota, after this Touch not work more.
Have tested with nother Touch working from another same device but not lucky.
Have flashed this with new FW by Odin and flash is OK, PASS but Touch continue not working, have tryed in all mode, is possible that only with an stupid update by Ota Touch not work More?,
Have flashed this FW:
PDA Version: I9200XXUDNE4
Phone Version: I9200XXUDNE4
CSC : I9200SERDNE4
Same version first of repair, Touch isn't broken, tested 3 more, and was working after changed New touch, update with Ota Stop Working, device is perfect in all.
Please anybody have solution for this?,
allumts
Old 09-24-2014, 11:06   #2 (permalink)
Member: 1961397
Thanks Meter: 3
i have the same problem any one can helps me????
Old 09-27-2014, 20:39   #3 (permalink)
allumts's Avatar
Member: 1564612
Please anybody can answer here?
allumts
Old 09-28-2014, 04:50   #4 (permalink)
Member: 1260512
Sonork: 100.1605447
Thanks Meter: 461
allumts
Bro allumts
i have I9205 after update touch not work too after i reflsh with octopus agian it work well,so pls try with octopus box.
Old 09-28-2014, 11:06   #5 (permalink)
allumts's Avatar
Member: 1564612
Originally Posted by 089999945 View Post
Bro allumts
Hello, you phone is I9205 my is I9200 and what change if flash with Octopus or with Odin, i think is Bootloader file wrong or with issues becouse other phones same problem, like I9300, I9500 itc..., flashing only Bootloader file phone working right.
Anyway this is SER code/country in Octopus Support not there's this Fw can have same or more high version of this fw you, i've all but only Odin fleshable.
allumts
Old 09-29-2014, 06:22   #6 (permalink)
Member: 1260512
Sonork: 100.1605447
Thanks Meter: 461
allumts
bro i mean need u reflash again by octopus with correct file,not tell u reflash with I9205.
Old 09-29-2014, 08:50   #7 (permalink)
allumts's Avatar
Member: 1564612
Bro, i've only changed Touch with new one and tested was working then phone was requesting for OTA update and i've done this.
At restart phone Touch no more working. have tested new one from another same I9200 with Touch full working but in this one same still problem.
Have download and flashed via Odin last version "Ser-I9200XXUDNE4" but phone still the same.
Now, you write of flash this with Octopus, but what change?, i know very good Octopus and many time Flash with this Fail but no with odin.
I want to listen you, please can suggest which Fw you think can solve this from Octopus support?, remember that i wont downgrade this device, (risk brick), but only to have Touch Working other time.
In many other devices i've flashd only Bootloader file and problem of Touch or gray lines have solved.
Please suggest which fw from Octopus support would you like to flash,
allumts
Old 09-29-2014, 10:33   #8 (permalink)
axecom's Avatar
Member: 1424719
Sonork: 100.1619833
Thanks Meter: 2,563
Hi,
Reflash it without screen. Then put screen again!
Regards,
Axecom
Old 09-29-2014, 18:18   #9 (permalink)
allumts's Avatar
Member: 1564612
Originally Posted by axecom View Post
Hi,
Regards,
Axecom
@axecom,
first i open other time this, you think this can work? ok want to try it.
WBR
Ripgsm
Old 09-30-2014, 10:56   #10 (permalink)
Member: 321237
hi all
i have the same problem , so is there any update ?
Old 09-30-2014, 13:34   #11 (permalink)
allumts's Avatar
Member: 1564612
Hi,
Regards,
Axecom
Have done this procedure then after i connect other time the Flat of touch/display i have seen with microscpie tha it is a small damged plastic part of connector.
I want to try changing Connector in PCB becouse with reflash not solve.
allumts
Old 10-07-2014, 19:11   #12 (permalink)
Member: 4731
Thanks Meter: 3
samsung I9205
HI
after upgrade ota not work touch i9205
Recovery meni touch work
How to downgrade without touch
thanks
Old 10-07-2014, 19:14   #13 (permalink)
allumts's Avatar
Member: 1564612
Originally Posted by gerpepi View Post
HI
thanks
what downgrade? brick only you phone if downgrade.
Old 10-07-2014, 19:30   #14 (permalink)
Member: 4731
Thanks Meter: 3
Hi
How to brick i9205
thanks
Old 10-07-2014, 19:32   #15 (permalink)
allumts's Avatar
Member: 1564612
Hi
How to brick i9205
thanks
Cannot downgrade, understand now? if want to try i've advised.
Page generated in 0.33107 seconds with 8 queries
