Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
10-09-2014, 14:39 | #18 (permalink) | |
No Life Poster Join Date: Dec 2002 Location: lebanon-tripoli
Member: 18966 Status: Offline Thanks Meter: 59 | Quote:
the problem appear if your lcd is not the original one solution 1 : replace lcd with original lcd i9205 or i9200 touch will work normally solution 2 without changing lcd : 1- root your i9200 ver 4.4.2 2- install recovery 3- install any custom rom based 4.2.2 enjoy note important : there is 2 models of copy lcd one will work normaly with this solution and the other will keep restart until you remove flex touch don't forget to press thank button if you see my solution usefull | |
The Following 4 Users Say Thank You to asmar For This Useful Post: |
10-12-2014, 11:25 | #22 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Anyway i not downgrade this phone for to have other more big problem after this. After what i do, Unbrick with Jtag and my problem is the same?, obvius!!! i think you not have read that the phone is over 4.4.2 fw, no issue for Root it, it's very easy, also can not confirm from SuperSU the Update binary and if want install Normal or from Recovery and if want disabilite Knox. Anyway isn't it the problem, Z3X can root it w/o problem. BR allumts | |
10-13-2014, 09:52 | #23 (permalink) | |
Member: 18966 Status: Offline Thanks Meter: 59 | GUIDE step by step how to repair Touch not work i9200-i9205 after ota update to 4.4.2 Quote:
1- Root your mobile (CF-Auto-Root-melius3g-melius3gxx-gti9200.zip) via odin or for i9205 search about the compatible root that it is easy 2- install recovery (philz_touch_6.25.0-melius3gxx.tar.rar) via odin 3- install custom rom i use (Simons_9200_Touchwiz_Rom_v211_based_on_BMJ2.zip) via memory card also there is custom rom for i9205 from Simons search about it note important :1- Do not disable knox 2- maybe you need update SU via market 3- as i said some model of copy lcd will not work with solution and keep restart until you remove the touch flex from lcd i think now it is clear and about downgrade with custom rom it will not brick your phone but i will not take any responsibility all done and enjoy also maybe some one can make patch for that problem inspiring from that solution don't forget my thanks button | |
The Following 2 Users Say Thank You to asmar For This Useful Post: |
10-13-2014, 12:30 | #24 (permalink) | |
Anyway is one temporary solution becouse as you said can be not work the same, sorry but not see more Thanks Button, sure is disabled but not understand WHY, ok the next, BR allumts | |
The Following 2 Users Say Thank You to allumts For This Useful Post: |
10-24-2014, 10:16 | #28 (permalink) |
No Life Poster Join Date: Jul 2003 Location: LEBANON
Member: 33690 Status: Offline Thanks Meter: 3,398 | anyone solved i have three of these phones, nearly new from the box. after change language through odin by someone, tough not working. tried several flashes 4.4.2 but no luck. so i took the risk by downgrading using I9200XXUAMEA_I9200OJVAME3_I9200XXUAMEA this flash. now touch is working but imei null. upgradede to 4.4.2 and touch stopped working. any ideas and have a nice day. |
10-24-2014, 12:09 | #29 (permalink) | |
I've changed connector lcd/touch in the pcb then replace touch/lcd with New ORIGINAL one, all is working good. BR allumts | |
10-24-2014, 21:29 | #30 (permalink) |
Member: 33690 Status: Offline Thanks Meter: 3,398 | not working why should i change the screen since it is original. already opened a new i9200 from the box with software I9200XXUDNF3 4.4.2 and installed board but touch not working. with version 4.22 touch is working and imei is null. it is still software problem. have a nice day |
