Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
09-19-2014, 20:08 | #1 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Samsung GT-I9200 AFTER OTA UPDATE TOUCH NOT WORK ???? Have tested with nother Touch working from another same device but not lucky. Have flashed this with new FW by Odin and flash is OK, PASS but Touch continue not working, have tryed in all mode, is possible that only with an stupid update by Ota Touch not work More?, Have flashed this FW: PDA Version: I9200XXUDNE4 Phone Version: I9200XXUDNE4 CSC : I9200SERDNE4 Same version first of repair, Touch isn't broken, tested 3 more, and was working after changed New touch, update with Ota Stop Working, device is perfect in all. Please anybody have solution for this?, Br allumts |
09-28-2014, 11:06 | #5 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Anyway this is SER code/country in Octopus Support not there's this Fw can have same or more high version of this fw you, i've all but only Odin fleshable. Br allumts | |
09-29-2014, 06:22 | #6 (permalink) | |
No Life Poster Join Date: Mar 2010 Location: Cambodia
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | Quote:
bro i mean need u reflash again by octopus with correct file,not tell u reflash with I9205. | |
09-29-2014, 08:50 | #7 (permalink) | |
At restart phone Touch no more working. have tested new one from another same I9200 with Touch full working but in this one same still problem. Have download and flashed via Odin last version "Ser-I9200XXUDNE4" but phone still the same. Now, you write of flash this with Octopus, but what change?, i know very good Octopus and many time Flash with this Fail but no with odin. I want to listen you, please can suggest which Fw you think can solve this from Octopus support?, remember that i wont downgrade this device, (risk brick), but only to have Touch Working other time. In many other devices i've flashd only Bootloader file and problem of Touch or gray lines have solved. Please suggest which fw from Octopus support would you like to flash, Br allumts | |
09-30-2014, 13:34 | #11 (permalink) | |
I want to try changing Connector in PCB becouse with reflash not solve. Br allumts | |
