Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 10-01-2010, 15:56   #1 (permalink)
akhil_bbsr's Avatar
Member: 271478
Sonork: 1590868
Thanks Meter: 1,005
Samsung I5700 (Galaxy SPICA) Android 2.1 Flashing Guide
What you need
(Odin_v4_03.exe + spica.ops)
Drivers for I5700 : drv5700.
Samsung USB Cable (attached at the end)
Before you start :
Backup your data !
Remove the SIM lock if any.
Create a folder and extract all files listed above + the firmware (do not extract the tar file from within the firmware)
Ensure your phones battery is sufficiently charged (and your laptops battery too if you live in a country like ours lol ;-))
Shutdown any service/software which could be using the USB port, especially the Samsung PC suite. - Very Important
Flashing :
Edit : You should probably do a hard reset before you start by punching in the following code on the phone *2767*3855#
1. Shutdown your phone and remove the SDCARD and the SIM
2. Put the phone in "Download Mode" by pressing Volume Down + Camera + Power button.3. Connect the Phone to the PC using USB
4. Install drivers using the drv5700 files-
Open your device manager and ensure the two Samsung devices are shown properly before you go ahead
5. Open Odin Multi Downloader v4.03.exe and then reconnect the phone, you should see the a COM port number with a yellow background.
6. Select the files as shown in the
you are using some other firmware and there is only one tar file select Option : One Package and load the file under One Package TAB.
Cross check the files and if you need to change anything click on "Reset Files" and select files again.
7. Once you are ready hit the START button. DO NOT DISCONNECT the phone until the firmware download completes.
8.Watch the "Message: window and wait till it shows <1> Close serial port and wait until rebooting.- This usually takes not more than 1-3 minutes.
9. At this point your flashing is complete and the device should be automatically rebooting, once the reboot is complete unplug the USB cable
The Following 6 Users Say Thank You to akhil_bbsr For This Useful Post:
Old 12-14-2010, 20:31   #2 (permalink)
Member: 1098957
Sonork: gsmfather
whr is firmwer boss .............................
Old 12-14-2010, 20:51   #3 (permalink)
Member: 1353395
Sonork: 100.1607424
Thanks Meter: 98
unlock problam s5600
Count supported models - 217
Searching Samsung USB interface... detected (COM6)
Model: GT-S5600V
SW: S5600BUIG2
IMEI: 35631703152698/9
Done with Samsung 3G tool ver 8.8
Model: GT-S5600V
SW: S5600BUIG2
No answer from phone
Error read info
Model: GT-S5600V
SW: S5600BUIG2
help mi
Old 12-15-2010, 14:06   #4 (permalink)
lindomarhostins's Avatar
Member: 878453
Thanks Meter: 7
I have this model right here and It's locked...
Flashing it with this process, will it be unlocked?
I'm just lost with it Coz a customer let this phone to me and I need to unlock it..
Someone can give me a light?
Thanks in advance
Old 06-29-2012, 22:54   #5 (permalink)
Member: 22284
Thanks Meter: 64
how to do this hard reset on i5700
Old 03-18-2013, 13:54   #6 (permalink)
ashish_telecom's Avatar
Member: 1870189
Thanks Meter: 32
Samsung I5700 Spica hard reset
USE THIS METHOD FOR hard reset your Samsung Samsung I5700 Galaxy Spica Android phoneress *2767*3855#
or key combo
PRESS VOLUME DOWN + CALL + DOWN ( OK DOWN ) + POWER ON (pls try other methods too if this is not working)
or PRESS VOLUME DOWN + CALL +END keys together.
PRESS both CALL + OK + END keys / buttons together for 10 sec.
If you have the too many incorrect patterns issue, try to block gmail account then type NULL for password. It works on older SW versions.
Other trick on locked phone if you call your locked phone then (back key ) go into Menu> security settings to take off the lock pattern.
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 14:12
Page generated in 0.43190 seconds with 8 queries
