Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
03-04-2015, 09:33 | #1 (permalink) |
Freak Poster Join Date: Jan 2015 Location: faisalabad
Member: 2323951 Status: Offline Sonork: 100.1668590 Thanks Meter: 86 | samsung i9300 flashing error |
03-04-2015, 13:37 | #5 (permalink) |
Freak Poster Join Date: Apr 2014 Location: ******.amman Age: 39
Member: 2168728 Status: Offline Thanks Meter: 45 | bro use odin 3.07 and run it as administrator use 4 file with pit ... and chick re-partion box thats it ur problem will be solved 100% i had the same problem with i9082 and its solved i almost beleved its hard ware issue ... but it wasn't BR don't forget thanx |
The Following User Says Thank You to majdiahmad For This Useful Post: |
03-04-2015, 13:54 | #7 (permalink) |
Member: 2323951 Status: Offline Sonork: 100.1668590 Thanks Meter: 86 | product code is shown ,,,, kindly confirm me emmc damaged or not, mobile is going into downloade mode not go into recovery mode when try to put recovery mode with key combenation vol up,pow,home downloade logo appers on screen its just logo not downloade mode ? Last edited by daniel@foji; 03-04-2015 at 13:59. |
03-04-2015, 14:07 | #10 (permalink) | |
Member: 2168728 Status: Offline Thanks Meter: 45 | Quote:
cuz u passed the setup conection step thats mean ur device in download mode 100% | |
03-04-2015, 14:13 | #11 (permalink) |
Member: 2323951 Status: Offline Sonork: 100.1668590 Thanks Meter: 86 | it mean when i try with vol up,home and pow key for recovery mode ,,,downloade mode logo appers its just logo ,,,set is going into downlode mode with vol,down,home and power key |
03-04-2015, 14:23 | #13 (permalink) |
Member: 2168728 Status: Offline Thanks Meter: 45 | have u try full flah ? you are waste ur time with posting without trying ... just make sure its not software issue after that think about hardware ... BR GL |
03-04-2015, 15:30 | #14 (permalink) |
No Life Poster Join Date: Sep 2013 Location: The Hell Age: 31
Member: 2033150 Status: Offline Thanks Meter: 624 | EMMC damge 100% also showing proudect code this error maybe fixed look at here http://forum.gsmhosting.com/vbb/f777...on-s3-1788325/ if not working then u have to change EMMC no way ........... |
03-04-2015, 17:00 | #15 (permalink) |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,126 | Odin always check pit before flash any file even 4 file or 1 file If pit fail then it's should be emmc fault.. Want to try 4 Files firmware then try and post result |
