Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 09-03-2012, 16:53   #1 (permalink)
sajidmirza's Avatar
Member: 256461
Sonork: 100.1608049
Thanks Meter: 90
Samsung I9300 - No audio during calls
Galaxy S3 I9300 No audio during calls ( no mic,receiver,speaker and headset).Can make and receive calls.Ringer is also working.
But it works fine when using skype and fring.
reason:used skype call and left it idle and when the gsm call received, audio went off.
hard reset--- not recovered
flashed with odin different firmwares--not recovered
flashed custom rom C9-------not recovered
updated to jelly bean 4.1.1----not recovered
replaced headset jack-------not recovered
flashed with SPT box I9300XXALEF---- lost network (only circle)
repaired imei and unlocked in SPT-----S/N-00000000,"not registered on network"
What may be the solution.Is it hardware or software issue.
Any idea will be appreciated.
sajidmirza
Old 09-14-2012, 15:18   #2 (permalink)
Member: 1781653
Sonork: Peewee_02
i have the same problem with you but no luck until now there are no solution.
Old 10-11-2012, 00:47   #3 (permalink)
Cheater -Don't Deal with him-
Member: 407564
Thanks Meter: 141
Today i get same prb i m searching difrent
Fourm some one say flash some one say hardwear
I do all same like u but same problem even root or update
Reset everything but same problem
Old 10-19-2012, 15:37   #4 (permalink)
Member: 456549
me too,, i have the same problem,,, sooo what the solution,,,,
Old 11-07-2012, 12:39   #5 (permalink)
Syed's Avatar
Member: 19979
Thanks Meter: 116
i had a phone with similar problem and only a flash with latest firmware on ODIN fixed it..
WBR
Syed
Old 11-08-2012, 09:23   #6 (permalink)
najegsm's Avatar
Member: 185396
Sonork: 100.1618832
Thanks Meter: 33
WBR
Syed
sir which firmware you done this problem? I have 2 units with my hand same problem i did all the way hardware but not done
plss help us
Old 11-08-2012, 09:55   #7 (permalink)
Syed's Avatar
Member: 19979
Thanks Meter: 116
i flashed phone with Australia Generic Retail firmware
download from here
WBR
Syed
The Following User Says Thank You to Syed For This Useful Post:
Old 11-10-2012, 23:02   #8 (permalink)
R3İS's Avatar
Member: 1058593
Sonork: 100.1625725
Thanks Meter: 433
try flash with any version but for repair imei use octopus even with 4.1.1 workıng perfect
Old 11-12-2012, 20:03   #9 (permalink)
Member: 112190
Thanks Meter: 21
I also have 3 pieces with no audio ,and I already tryed a lot of software versions and still the same
I'm start thinking hardware....................
any clue??
best regards
linterna1
Old 11-26-2012, 15:54   #10 (permalink)
shachash's Avatar
Member: 51905
Thanks Meter: 41
same problem here.. have 3 pcs no audio during call
any solution ???
Old 11-27-2012, 12:23   #11 (permalink)
Member: 306828
Thanks Meter: 8
hi everyone.i worked hard and i found solutions for audio problem in during calls i9300.it s a hardware problem.i will reply pm .thanks..
Old 11-27-2012, 17:36   #12 (permalink)
shachash's Avatar
Member: 51905
Thanks Meter: 41
What is your solution? we need it
thanks in advance
Old 12-01-2012, 10:25   #13 (permalink)
Member: 306828
Thanks Meter: 8
this is solution
Old 12-01-2012, 10:45   #14 (permalink)
Member: 306828
Thanks Meter: 8
sorry guys.some problem with sharing photo.i added to attachement.
The Following 2 Users Say Thank You to djender For This Useful Post:
Old 12-01-2012, 15:05   #15 (permalink)
Member: 31604
Thanks Meter: 12
this ic is glued....its risky unless u r sure it is the right solution
My 6150 (5.23) No network after Flashing AboAli Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 01-31-2001 15:56
6150 no outgoing calls edis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-20-2000 20:19
Nokia 6110 without net. couldnīt call 911 either! DennisT Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 05-09-2000 11:37
no one can unlock 6110 05.40 25-5-99 fondas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 09-22-1999 08:03
Page generated in 0.25083 seconds with 11 queries
