Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 12-01-2012, 15:08   #16 (permalink)
Member: 31604
Thanks Meter: 12
any other ideas brothers .... this problem is with many phones now
Old 12-01-2012, 15:23   #17 (permalink)
canliyayin's Avatar
Member: 311558
Thanks Meter: 476
EFS must repair.other methods did not work
Old 12-01-2012, 15:39   #18 (permalink)
Member: 476075
Sonork: na
Thanks Meter: 40
dear all open your phone and remove charging base connector and check head set working or not, if yes then replace charging flex.
best regards.
Old 12-01-2012, 15:43   #19 (permalink)
Member: 476075
Sonork: na
Thanks Meter: 40
best regards.
Old 12-01-2012, 16:31   #20 (permalink)
Member: 306828
Thanks Meter: 8
guys you want solution.i shared solution.yes i know this ic with glue.but there is no another solutions.i repair 17 pcs s3 in 3 days.i said true.but if you want you flash another rom or repair efs.but don't forget.it s real solution.i didn'twant money or other things from you.i am only want to help you.i dont understand some people still say software is the solution.yes its true software is solution when software has a problem.who can repair hardware problem with software can you tell me?
The Following 2 Users Say Thank You to djender For This Useful Post:
Old 12-01-2012, 16:44   #21 (permalink)
Member: 306828
Thanks Meter: 8
and don't forget.samsung used very very soft glue.it s not too hard.only you must be a little carefully.thats all
Old 12-01-2012, 18:26   #22 (permalink)
Member: 31604
Thanks Meter: 12
thanks for the solution pal... i really appriciate ur help here . i dont know abt others but i am highly obliged ..
thanks
Old 12-01-2012, 19:28   #23 (permalink)
Member: 31604
Thanks Meter: 12
i tried and its done... i have been looking for this solution for a very long time .thanks ... n *** bless
Old 12-01-2012, 20:35   #24 (permalink)
azharjamal's Avatar
Member: 804115
Sonork: 1658994
Thanks Meter: 13
flash with 4.1.2 will be allright
Old 12-05-2012, 18:37   #25 (permalink)
Cheater -Don't Deal with him-
Member: 407564
Thanks Meter: 141
brother i done its not ic or charging base its lcd problem so much copy lcd in market thats not orignal change orignal then working perfect
Old 12-09-2012, 23:05   #26 (permalink)
Crazy Poster
Member: 141715
Thanks Meter: 3
it's not flash problem, u pay flash-it with all flash in this world.
the solution is, when in call, press the touch in left of the home botton
( that touch usually is not visible ), than u will see " Noise reduction off "
Old 12-10-2012, 01:53   #27 (permalink)
Member: 407564
Thanks Meter: 141
yes u r right but brother its not work all
its work some but check lcd its lcd problem
in market so much copy lcd is not gud quality
Old 01-07-2013, 21:35   #28 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 991
can you check and share
what condition of phone after remove this ic.....
mean phone is power on and working all other feature without ic......
thanks
Old 01-08-2013, 00:27   #29 (permalink)
R3İS's Avatar
Member: 1058593
Sonork: 100.1625725
Thanks Meter: 433
here factory bulten for finish all sound problem
https://hotfile.com/dl/187885240/c39...Audio.pdf.html
Old 02-20-2013, 18:43   #30 (permalink)
i am the master's Avatar
Member: 996052
Thanks Meter: 35
i9300 no sound during the call.. solution
hello guys,
i was reading up all you guys have same problem with s3 no sound on call
i had same problem but i fixed it by flashing with this firmware I9300XXELLA_I9300OXFELL1_I9300XXELLA_HOME.tar.md5
with nspro[email protected]
My 6150 (5.23) No network after Flashing AboAli Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 01-31-2001 15:56
6150 no outgoing calls edis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-20-2000 20:19
Nokia 6110 without net. couldnīt call 911 either! DennisT Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 05-09-2000 11:37
no one can unlock 6110 05.40 25-5-99 fondas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 09-22-1999 08:03
Page generated in 0.28175 seconds with 10 queries
