Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
09-12-2011, 18:13 | #1 (permalink) |
Freak Poster Join Date: Oct 2006 Location: manila,philippines Age: 42
Member: 366425 Status: Offline Thanks Meter: 22 | galaxy s i9000 restart problem i flashed with odin downloader but still restarted,.. repair by riff but still problem persist mobileis restaring ive used these file: GT_I9000_JPJV6_JXJV6_OJPJV6_Sbl with 512.pit I9000JHJV8 w/ 512.pit I9000XXJVR SWC w/ 512.pit all of those were unable to repair i9000,but im sure those files were working as i have tested by me personally before, maybe a firmware compatibility? by the way ive got 4 pcs before with the same prob and still got no idea these mobiles were purchased here in saudi arabia so im guessing i should be using an arabic firmware like those above... pls help need some enlightment |
09-14-2011, 19:40 | #3 (permalink) |
No Life Poster Join Date: Jul 2005 Location: France Age: 48
Member: 165812 Status: Offline Sonork: 100:1627635 Thanks Meter: 4,267 | Look Bro For Tested Guide Check Here Then Try This: Get this FW I9000XXJPU and flash three files with pit too Phone must be on and work. After that Take this FW for Arabic 2.3.3 and flash it without pit file to make it arabic Share If U Care |
The Following User Says Thank You to tsarkh For This Useful Post: |
09-15-2011, 16:10 | #5 (permalink) |
Member: 366425 Status: Offline Thanks Meter: 22 | id tried tsarkh procedure but still doesnt work.... im beggining to lose hope... any other way? theres an error and it says: E: failed to mount data (file exist E:delete_data_files:cant mount /data your storagenot prepared yet,please use ui men u for format and reboot action |
09-15-2011, 19:31 | #6 (permalink) |
Member: 366425 Status: Offline Thanks Meter: 22 | ok, i kinda sort out the problem, the phone did boot up regardless of what version i put on,but the memory card (4gb) should be inserted. in short,in order for phone to boot up normally there should be a memory card inserted and when i browse in "my files" it says no memory card inserted and inside settings > sd card > it says not available pls someone have an idea on this? thanks |
07-10-2015, 22:03 | #10 (permalink) |
No Life Poster Join Date: Mar 2005 Location: wales uk
Member: 125632 Status: Offline Thanks Meter: 233 | E: failed to mount data (file exist E:delete_data_files:cant mount /data your storagenot prepared yet,please use ui men u for format and reboot action you se this after flashing... your memory built into the i9000 is either wrong format,or totally xxxxed,or you have done the memory mod lag fix all is explained at this link Code: http://forum.xda-developers.com/showthread.php?p=30415128#post30415128 all is explained easily,how to fix this prob.... good luck all note to mod,,,please allow this link,as it has all the ans for probs with the i9000....thanks to "xsenman" |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
