Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 02-17-2018, 20:17   #1 (permalink)
Member: 278395
Samsung Note 8 N950U Rent A Center Lock Help!
I need your help please, some months ago i bought a phone to a "Friend", he said the phone is new and unlocke, i use for near to 3 months but the last week appear a Rent A Center Lock, i talk to the RAC phone, and they tell me that the cellphone was stolen from the store, and they cant do something, i need to repair the phone because is from my wife, i already try to hard reset, i try with the compilation file and try to send some commands to erase the partition but appear "Permission Denied", i will appreaciate your help, thanks in advance, and sorry for my english
Old 02-20-2018, 05:23   #2 (permalink)
Member: 2575858
Thanks Meter: 20
flash n950u1
try and flash n950u1 rev 2 in prince comsy odin
Old 03-02-2018, 20:16   #3 (permalink)
xx0o0xx1's Avatar
Member: 2033150
Thanks Meter: 624
well, i suggest u to return it back to that FRIEND that u bought for the first place
Old 03-02-2018, 23:14   #4 (permalink)
Member: 2592628
Thanks Meter: 212
solution
I can remove RAC from G950U. FRP has to be off.
message for solution, not free.
Old 06-24-2018, 05:40   #5 (permalink)
Member: 2151398
obliviousmnd Do u have something for s8 sm-g950u1 bin 2 thanks in advance
Old 06-27-2018, 10:39   #6 (permalink)
Temporary banned !!
Member: 2511938
Thanks Meter: 123
i can remove rent a center n950f
n950u not test
if u have phone text me i can test
Old 07-01-2018, 08:44   #7 (permalink)
Member: 2718897
Thanks Meter: 49
lmao, some friends you have..
Sent from my SM-G965U1 using Tapatalk
Old 08-13-2018, 19:22   #8 (permalink)
Member: 1391794
Thanks Meter: 54
any possible way to force download mode when they are RAC locked?
Old 08-14-2018, 07:37   #9 (permalink)
Temporary banned !!
Member: 2511938
Thanks Meter: 123
yes i can
text me if need
Old 09-16-2018, 16:42   #10 (permalink)
Member: 2262723
not easy
I have done it before, its not easy, I can guide you. send me a message. I wont charge
Old 09-16-2018, 16:48   #11 (permalink)
Member: 2262723
TIP: here is a tip, you need to Trip Knox
The Following User Says Thank You to EdgarCh For This Useful Post:
Old 09-22-2018, 03:04   #12 (permalink)
Member: 92260
Thanks Meter: 843
If it allows you, flash combi, full factory reset, then do:
adb shell dd if=/dev/zero of=/dev/block/platform/<find _the_path>/by-name/persdata
adb shell dd if=/dev/zero of=/dev/block/platform/<find _the_path>/by-name/persist
<find _the_path> means you have to find the correct path for your device by something like:
adb shell ls -la /dev/block/platform/
If the "dd" gives a write error then you must flash it with an eng-boot first, and repeat the above commands.
Then flash with 4-file firmware and select the CSC-HOME instead of just CSC.
I see lots of free help offers, but don't worry you can post it here, if it exists Sammy knows about it already
Old 10-05-2018, 03:14   #13 (permalink)
anglngr9's Avatar
Member: 1745496
Thanks Meter: 68
Hey sorry to ask Im a little confused on what find the path means, i have read in a couple of forum they all mention this but cant figure out what it means
thanks in advance
Old 10-18-2018, 01:09   #14 (permalink)
Member: 2300959
Thanks Meter: 41
Hi.. can you help .. I have Samsung S8 g950f android 8.0 and I can't remove rent a center .. i can install combination but I don't know what to do..
Old 10-18-2018, 05:23   #15 (permalink)
Member: 2300959
Thanks Meter: 41
but how i will find the correct path???
Page generated in 0.22014 seconds with 8 queries
