Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
02-17-2018, 20:17 | #1 (permalink) |
Junior Member Join Date: May 2006
Member: 278395 Status: Offline Thanks Meter: 1 | Samsung Note 8 N950U Rent A Center Lock Help! |
02-20-2018, 05:23 | #2 (permalink) | |
Freak Poster Join Date: May 2016
Member: 2575858 Status: Offline Thanks Meter: 20 | flash n950u1 Quote:
07-01-2018, 08:44 | #7 (permalink) | |
Freak Poster Join Date: May 2017 Location: USA
Member: 2718897 Status: Offline Thanks Meter: 49 | Quote:
Sent from my SM-G965U1 using Tapatalk | |
09-22-2018, 03:04 | #12 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Quote:
If it allows you, flash combi, full factory reset, then do: adb shell dd if=/dev/zero of=/dev/block/platform/<find _the_path>/by-name/persdata adb shell dd if=/dev/zero of=/dev/block/platform/<find _the_path>/by-name/persist <find _the_path> means you have to find the correct path for your device by something like: adb shell ls -la /dev/block/platform/ If the "dd" gives a write error then you must flash it with an eng-boot first, and repeat the above commands. Then flash with 4-file firmware and select the CSC-HOME instead of just CSC. I see lots of free help offers, but don't worry you can post it here, if it exists Sammy knows about it already | |
10-05-2018, 03:14 | #13 (permalink) | |
Freak Poster Join Date: Apr 2012
Member: 1745496 Status: Offline Thanks Meter: 68 | Quote:
thanks in advance | |
10-18-2018, 01:09 | #14 (permalink) | |
Freak Poster Join Date: Nov 2014
Member: 2300959 Status: Offline Thanks Meter: 41 | Quote:
10-18-2018, 05:23 | #15 (permalink) | |
