Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 08-14-2011, 22:18   #1 (permalink)
MUTUAL's Avatar
Member: 160928
Thanks Meter: 338
Samsung p1000 after flash phone stuck on samsunf logo?
HI GUYS I M HAVING PROBLEM ON SAMSUNG P1000 GALAXY TAB PHONE CAME HERE FOR FLASHING 2.3.3 I TRY TO FLASH WITH P1000XXJMQ ## AFTER FLASH PHONE STUCK ON SAMSUNG LOGO WHAT TO DO HOW DO I FIX? IT CAN FLASH PROPER BUT WHEN I TURN ON STUCK ON LOGO.
WHEN FLASH COMPLETED ON THE PHONE SCREEN GIVING THIS ERROR WHILE INSTALL SOME SOFTWARE
Upon installing update assert failed: getprop("ro.product.device") == GT-P1000 and so on for each GT model and then Error in /cache/recovery/sec_csc.zip (status 7).
The wipe cache fails with E:format_volume: rfs format failed on /dev/block/stl11 the wipe data/factory reset also failed on /dev/block/mmcblk02p , stl10 and stl11
PLZ SOMEONE KNOWS WHAT TO DO U ?
THANKS SALIM
Old 08-15-2011, 17:29   #2 (permalink)
Cheater -Don't Deal with him-
::gsmcoder::'s Avatar
Member: 172434
Sonork: 100.161280
Thanks Meter: 577
follow these steps to recover your phone first
download this firmware
P1000JPJM5.z01
open odin
tick repartion and the other two
select p1000 hidden pit in the pit tab, google and download it
put your phone in download mode by holding volumedown+power
connect to pc, when odin detects, click start
when odin shows passed
put phone in download mode again, click reset on odin, open the downloaded firmware
and select pda, modem,csc, dont choose pit
connect phone again and click start, may take up to 2 minutes to start but be petient
till odin finish and shows pass
phone will reboot and be ok. firmware rar pass is ****************
Old 08-15-2011, 17:33   #3 (permalink)
Member: 172434
Sonork: 100.161280
Thanks Meter: 577
follow this guide to upgrade to 2.3.3
download these files
2.3.3 firmware Multiupload.com - upload your files to multiple file hosting sites!
mr pit http://www.thegalaxytabforum.com/ind...&attach_id=156
dbdata file http://www.thegalaxytabforum.com/ind...&attach_id=157
odin 1.85 http://www.thegalaxytabforum.com/ind...&attach_id=158
0. Preparing to Flashing the firmware
1. Take the main firmware and unzip the file using winzip or another extraction program. When it unzips you will be left w/ a .tar file. This is the file you will need to flash.
2. Unzip ODIN V1.7. You will have several files in the folder. you will use the file called Odin.exe
3. Unzip the pit file. you will be left w/ a .pit file
4. Unzip the dbdata file and you will be left w/ a file named dbdata.tar.
Take all those files and put them in a folder inside the main folder so they are in one spot and easy to find.
1. Flashing the Firmware
1. Double click ODIN.exe to run the program.
2. Make sure your tab to turned off. Hold the Power and Volume down button at the same time and it will have a android guy in a triangle w/ a shovel and hook it up to your computer. This is the download mode.
3. in the PDA section of odin place the main firmware .tar file in that section.
4. Place the .pit file in the pit section and make sure repartition is selected.
5. Hit start and it will flash the firmware.
2. Second Phase to flashing Firmware
you tab will reboot after the firmware flashes. Shut it down.
1. Place tab in DL mode again and hook it up to your computer. Power button and Volume Down at the same time.
2. Place dbdata.tar into the PDA section in ODIN (DO NOT SELECT REPARTITION)
3. Hit start and it will flash the .tar file.
4. Shut down the tab.
3. Phase Three of Flashing Firmware
We will be placing your tab into recovery mode. In Recovery Mode you will use the volume up and down keys to navigate and home key to select.
1. Hold Power and Volume up together.
2. Release Power after holding it for about 4-5 second and continue to hold the Volume Up button until recovery menu shows up.
3. Select wipe cache (When Done go to next step)
4. Select wipe data/factory reset.
5. Select reboot and you are done. You now have Android 2.3.3 Gingerbread.
The Following 2 Users Say Thank You to ::gsmcoder:: For This Useful Post:
Old 08-15-2011, 20:33   #4 (permalink)
MUTUAL's Avatar
Member: 160928
Thanks Meter: 338
thanks man i solve my problem u need to flash dbdata file to make it work thanks for ur info replly Appreciated
Old 08-17-2011, 11:12   #5 (permalink)
Member: 3279
Thanks Meter: 19
I have followed all these steps , however when placing in Recovery Mode , Screen is all scrambled , i cannot read anything , same problem , during initial start up , scrambled display , then works fine , when activating camera , scrambled display , any solution for this problem
Old 08-17-2011, 11:15   #6 (permalink)
Malik Irfan85's Avatar
Member: 1484062
Sonork: 1610135
Thanks Meter: 218
your flash file is not ggod
Old 08-17-2011, 11:25   #7 (permalink)
Member: 3279
Thanks Meter: 19
The tablet works except for the display
That scrambles. If the file was faulty
The device would not work then
Old 09-01-2011, 11:20   #8 (permalink)
Member: 93284
Thanks Meter: 202
P1000JPJM5.z01
open odin
Hi
I tried almost all your suggestions and always when I flash with Odin I have Failed at the end (see pict)
I tried to flash also with SPT and Z3X and then its always success but phone doesn't start . Sometimes stuck at samsung logo sometimes start in recovery and show error like at pict. I tried after that flash only dbdata but it doesn't change anything.
Ane idea what to do else?
Old 09-01-2011, 12:22   #9 (permalink)
RNC_EBM's Avatar
Member: 101860
Sonork: 100.1582168 100.77603
Thanks Meter: 6,036
NEED:
= P1000DXJPI_P1000DXJPE_P1000OLBJPH_HOME - LATEST aOS 2.3.3
= Odin 1.7
Procedure:
= before flashing, go to RECOVERY MODE
= " Wipe Data/Factory Reset "
= " Wipe Cache Partition "
= reboot
= PUT in DOWNLOAD MODE
= get "gt-p1000_mr.pit" inside .TAR FILE
= open ODIN, at PIT, choose "gt-p1000_mr.pit"
= at pda, choose the .tar file
= CHECK RePartition, Auto Reboot & F. Reset Time
= connect your phone must be in DOWNLOAD MODE
= CLICK Start
= wait until finished, after FLASHED, it will automatically go to DOWNLOAD MODE
= again, NO PIT FILE
= at PDA, choose TAR File
= UNCHECK Re-Partition, CHECK Auto Reboot & F. Reset Time
= CLICK START
= AFTER FLASHED, go to RECOVERY MODE
= REBOOT
= DONE
HOPE THIS WILL HELP
br
The Following 2 Users Say Thank You to RNC_EBM For This Useful Post:
Old 09-01-2011, 12:57   #10 (permalink)
Member: 93284
Thanks Meter: 202
Originally Posted by RNC_EBM View Post
NEED:
= Odin 1.7
Procedure:
= reboot
= CLICK Start
= CLICK START
= REBOOT
= DONE
HOPE THIS WILL HELP
br
Thanks for help but at this point
= wait until finished, after FLASHED,HERE it will automatically go to DOWNLOAD
process fail (like at pic)
After all tried to flash without pit file but also fail
Old 09-01-2011, 13:26   #11 (permalink)
RNC_EBM's Avatar
Member: 101860
Thanks Meter: 6,036
okay, this time try to repair thru JTAG, i recommend RIFF BOX
then follow my PROCEDURE ABOVE.
if still the same, it's hardware problem
br
The Following User Says Thank You to RNC_EBM For This Useful Post:
Old 09-01-2011, 13:56   #12 (permalink)
Member: 93284
Thanks Meter: 202
it's not my phone and I don't know what happened before but isn't it strange that when try to do factory reset from recovery then this error appear:
E:format_volume:rfs format failed on /dev/block/mmcblk0p2 ??
doesn't it look like HW?
Old 09-01-2011, 14:48   #13 (permalink)
Member: 93284
Thanks Meter: 202
one more thing, now after flashing with only .pit phone restart and show this
(see pict)
don't you think it's damaged memory?
Anyway Thanks for your time
Old 09-04-2011, 18:03   #14 (permalink)
Member: 172434
Sonork: 100.161280
Thanks Meter: 577
(see pict)
no damaged memory you must flash a stock rom of 2.1 then upgrade
do this
get the JM5 firmware with link in my first post
get hidden pit
extract firmware
load hidden pit
load pda
load phone
load csc but dont check repartition
click start
once job is complete
reboot into recoevry and do wipe cache and factory reset.
upgrade to any version u wish or stay on 2.1
Old 09-04-2011, 18:05   #15 (permalink)
Member: 172434
Sonork: 100.161280
Thanks Meter: 577
very important
the state of your phone you must flash a file that has pda, phone and csc.
only pda tar wont help you
so folow ma last procedure.
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
Page generated in 0.29249 seconds with 11 queries
