Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
04-04-2013, 16:05 | #1 (permalink) |
No Life Poster Join Date: Jul 2007 Location: tr
Member: 539148 Status: Offline Thanks Meter: 2,174 | [Root] step by step Manual i9500 Galaxy S4 Let me remind u that I will not be held liable for any mishap, therefore, proceed at your own risk. Pre-requisites 1) Download and install USB Driver for Samsung Galaxy S4 on the computer. 2) Verify that USB Debugging Mode is enabled which will allow to connect the phone with the computer and use the Android SDK with it. [Press Menu>> Settings>> Applications. From there navigate and click on Development option and ensure the USB Debugging Mode is turned on.] 3) Create a backup of all data of the phone. 4) The battery of the device should have above 80 per cent charge. 5) The root method works only on the Samsung Galaxy S4 I9500 running on Android 4.2.2 XXUAMC6 Jelly Bean; applying this root to incorrect variants will brick the device. Steps to root Samsung Galaxy S4 I9500 on Android 4.2.2 XXUAMC6 Jelly Bean 1) Download I9500XXUAMC6_I9500OXAAMC6_ROOT_ODEX for Samsung Galaxy S4 to the computer and extract the zip file 2) Download Odin3-v1.85.zip which will help to root the Jelly Bean firmware 3) Turn off the Galaxy S4 and enter Download Mode. Press and hold Volume Down + Home buttons together and then press the Power button until the construction Android robot and a triangle are seen. Press the Power button again to enter Download Mode 4) Run Odin on the computer 5) Connect the phone to the computer using USB cable while it is in Download Mode. If the device is connected successfully, one of the ID: COM boxes will turn yellow with the COM port number. This step might take some time 6) Select the files mentioned below to install on the phone a) Click on 'PDA' and select file with 'CODE' in its name b) Click on 'Phone' and select file with 'MODEM' in its name c) Click on 'CSC' and select file with 'CSC' in its name d) Click on 'PIT' and select the .pit file [Note: Ignore the last three steps in case such files are not found.] 7) Ensure the 'Auto Reboot' and 'F Reset Time' options are selected in Odin. Also ensure the 'Re-Partition' option is selected in case the .pit file is being used 8) Double check everything and finally click the 'Start' button in Odin. The installation process will begin and take a few minutes to complete 9) After the installation process is completed, the phone will restart automatically. Once the home screen appears on the device, unplug the USB cable Samsung Galaxy S4 I9500 is now successfully rooted on Android 4.2.2 XXUAMC6 Jelly Bean firmware. Open the app drawer in the phone and search for an app called Superuser. To ensure that the above root method is installed and working correctly, verify with the Root Checker app from Google Play Store. Last edited by moulnisky; 04-04-2013 at 23:58. |
The Following 5 Users Say Thank You to dicle_gsm For This Useful Post: |
05-03-2013, 16:12 | #2 (permalink) |
Freak Poster Join Date: Feb 2012
Member: 1717511 Status: Offline Thanks Meter: 5 | HI, i downloaded already the file, but why I only get the CODE part, I cant see MODEM, CSC or pit file. Please because im trying to fhash only the code and always appear FAIL in the beggining of the process. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> CODE_I9500XXUAMC6_I9500OXAAMC6_ROOT_ODEX.tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/356> Odin v.3 engine (ID:356).. <ID:0/356> File analysis.. <ID:0/356> SetupConnection.. <ID:0/356> Initialzation.. <ID:0/356> Get PIT for mapping.. <ID:0/356> Firmware update start.. <ID:0/356> system.img <ID:0/356> NAND Write Start!! <ID:0/356> <ID:0/356> Complete(Write) operation failed. <OSM> All threads completed. (succeed 0 / failed 1) |
05-04-2013, 03:03 | #5 (permalink) |
Super Moderator Join Date: Jul 2008 Location: Villa del rosario/Nsd Colombia
Member: 813309 Status: Offline Thanks Meter: 1,912 | |
05-05-2013, 12:32 | #6 (permalink) | |
Member: 539148 Status: Offline Thanks Meter: 2,174 | Quote:
I tested and successful | |
05-13-2013, 15:58 | #8 (permalink) | |
No Life Poster Join Date: Apr 2011
Member: 1552610 Status: Offline Sonork: 100.1604734 Thanks Meter: 1,370 | Quote:
fake proccess br saqib iqbal | |
