Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
05-04-2019, 10:04 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: philippines Age: 42
Member: 388962 Status: Offline Sonork: 100.1637202 Thanks Meter: 263 | samsung RPMB fuse problem 1 is c7010 and t380 they only have frp after i tried downgrading with combination file it is now stuck in download mode with RPMB fuse : -2 RPMB PROVISIONED RP SWREV : s-2 t-2 r-2 a-2 p-2 and it will not accept any firmware anymore, latest and combination of any firmware anyone knows where is the RPMB fuse located? |
The Following User Says Thank You to eivelice For This Useful Post: |
05-12-2019, 23:56 | #2 (permalink) |
Junior Member Join Date: Mar 2013
Member: 1899511 Status: Offline Thanks Meter: 23 | Fuse -2 happened to my T380 Tab A tablet when I flashed wrong aboot and boot in the same TAR package. So steps to fix it: find the right combination firmware; unzip it with 7zip archiver; download TAR_MD5_PACKAGER; open folder with unzipped comb_firmware and delete all files below from it: -aboot, -apdp, -boot, -devcfg, -msadp, -rpm, -sbl1, -tz. copy all files what left to TAR_MD5_PACKAGER\parts; start TAR_MD5_PACKAGER and press 1 to make tar file; flash this file with Odin as AP; now the fuse should switch to 1; next flash the full combination file or stock firmware. FUSE Number stands for software version, samsung has protection against downgrading software, So once you flashed firmware with number 2 in it, the device will change the fuse to 2 and after that you will not able to flash anything less than with number 2 and so on. |
The Following 3 Users Say Thank You to icealex19 For This Useful Post: |
05-17-2019, 11:44 | #4 (permalink) | |
Member: 388962 Status: Offline Sonork: 100.1637202 Thanks Meter: 263 | Quote:
05-23-2019, 03:40 | #5 (permalink) |
Member: 1899511 Status: Offline Thanks Meter: 23 | Video solution fix for fused -2 Check the video - !! remove spaces in the link !! https://www.youtube.com/watch?v=XqU-WUZYgbY&t=145s |
05-24-2019, 18:14 | #6 (permalink) |
No Life Poster Join Date: Apr 2004 Location: MOON
Member: 60899 Status: Offline Thanks Meter: 792 | t380 fix this fuse problem: h_ttps://forum.xda-developers.com/galaxy-tab-a/help/help-tab-t380-oreo-flashing-t3857266 |
The Following 2 Users Say Thank You to mrfixit For This Useful Post: |
