Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
11-03-2014, 10:20 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Jan 2006 Location: BANGLADESH
Member: 225400 Status: Offline Thanks Meter: 17 | samsung s duos 2 s7582 stuck on logo pls guide I FLASHED WITH LATEST 2 VERSIONS also flasg 4 file maulti pack firmware . also octoplus box firmware flash but same problem HARD RESET IS EVEN NOT WORKING not goes to recovery mode . plz help me thanks in advanced. |
11-03-2014, 12:02 | #2 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Try diff region firmwares DBT Germany,TPH Portugal in odin uncheck auto boot nd flash after flash done remove battery 20 sec after insert nd pwr on manually IF not solve may b efs corrupted Reset efs nd check Note: if yu reset efs yu vil lose yur og imei so yu hav to repair imei den |
The Following User Says Thank You to jamesjerss For This Useful Post: |
11-25-2014, 08:08 | #3 (permalink) |
Junior Member Join Date: Nov 2014
Member: 2299122 Status: Offline Thanks Meter: 0 | i have the same problem,, my sduos 2 stuck on logo, then the screen flicker. i did flashing new firmware, hard reset, clear cache, and etc... what i did to fix it was,, i change the motherboard of the device.. it cant be fix by programming.. now i fix my sduos 2... |
